How can I tell which motor is a CW or CCW on the Phantom 2 Vision...
6508 6 2016-5-8
hlthcareit
Hi - I fried a motor by using too long of screws on prop guards.  Purchased both a CW (clockwise, and CCW - counter motor to replace it.  How can I tell which to use.
The motor is in the rear right 5 o-clock position.
Thanks for any advise.
Happy droning,
Pete
2016-5-8
nigelw
Flight distance : 518084 ft
They'll have opposite threads on if it's the same as the P3.  Just fit the motor with the same thread that's on the diagonally opposing arm of the aircraft.
2016-5-8
Kneepuck
Flight distance : 275105 ft
Or start the motors and observe.  The dead motor will rotate the same direction as the one diagonally opposite to it.
2016-5-8
rayrokni
Flight distance : 8139875 ft
The motors threads are color coded
2016-5-8
Homer Simpson
2 are silver 2 are black.
2016-5-8
Northofthe49th
Tip of the motor will match what you are replacing with,
CW is black and should be same as top of prop
CCW is Silver and as above
2016-5-8
soldk
Denmark
https://forum.dji.com/thread-272667-1-1.html
2022-10-10
