RedHotPoker
Flight distance : 165105 ft
With all these questions you should RTFM. ;-)
1. No, not any for us.
2. Cache the map so it appears at the chosen flying area, if you have no WiFi there.
3. If the battery voltage gets too low, the drone will auto land. And that could be at the top of a tall tree, or into a wet deep drink...
4. Some of us, prefer to do a soft break in of flight batteries, fly to 50% charge first ten flights. Deep cycle the intelligent flight battery, drain down to 8% after every twenty full charges.
5. Not sure about that, "Enable Sync Gimbal Pan Follow"?
6. A cold IMU calibration is mandatory. The gimbal calibration is done right after. Be sure you are situated on a flat surface. Compass calibration needs to be done outside.
7. Smart Return Home should be On. No question. Unless flying indoors. Hahaha
8. That 6000' is flying safely above sea level. Legally, 400' is our ceiling...
Hope you can RTFM several more times before arming the motors. Ha
Have fun, fly safe, happy landing.
RedHotPoker |
