Dji please make auto brake off/on feature.
1601 6 2016-5-9
leanlinao
Flight distance : 1495906 ft
Philippines
The auto brake feature is for beginners mainly.
It uses more battery rather than just letting the drone glide.
Letting the drone glide in clear air lets a single pilot get a moving shot easier using the yaw of the camera.
2016-5-9
RichJ53
Flight distance : 1837356 ft
The brake feature is really not for beginners.... it is a feature while in GPS mode that helps you maintain position while you are flying, I have mine set at 70( is the lowest setting).
If you want to glide your Inspire, put it into Att mode and the Inspire will do exactly what you need during flight.
Rich
2016-5-9
DJI-Ken
Flight distance : 1515312 ft
You can turn it down all the way and the stop will not be abrupt.
2016-5-9
Farnk666
Flight distance : 1711394 ft
That's what ATTI is for.
2016-5-9
leanlinao
Philippines
Farnk666 Posted at 2016-5-10 06:29
So atti mode will disable the auto brakes?
2016-5-9
Farnk666
Yes, but it won't GPS hold position. When you throttle back, it will keep going at its current course and speed.
Have you read through the manual?
2016-5-11
Nigpd
Flight distance : 597677 ft
Farnk666 Posted at 2016-5-11 14:13
There's a manual for the Inspire??????????????
2016-5-11
