hobbyteam
Flight distance : 65039 ft
Greece
Hello please i would like your help as i have the same issue, since i updated to 1.9.60 firmware version on the P3A and the goapp android version 3.1.0 i cant see the firmware version on the about section.
Instead i get a N/A note. But on the sd card i can see that the firmware was installed. I do get the app version and the controller serial number. I use a "non" recommended device such as Sony Xperia M4 Aqua, ZTE s8Q+ but i also have the same result with recommended devices such as Samsung Note 3. Everything else seems to work correctly. Could you please help?Do you have any idea why is that happening? Because when the latest firmware version for P3A was released, the 1.10.90 the goapp did not advice to update i believe because it cant read the current installed firmware version. With all previous firmware versions i did not have any issues with the mentioned devices, and i still dont have when i use them with the osmo. Tried everything, reinstalling the app,formatting the sd card, nothing worked!!!Thank you in advance, kind regards Tassos Dukakis. |
