Google Maps doesn't seem to be working offline
3143 20 2016-5-10
wellsi
Flight distance : 8330187 ft
Hello guys
Google Maps has recently stopped working offline for me on my Android Go app.  All my flight records show 'Map Loading' for the location and during the flight I just have a blurred very low res map.
I've checked by offline maps is up to date and works when I actually use Google Maps offline.  I've also checked the Go App has 'cache maps' ticked.
Anyone else suffering this or have I got a setting wrong?
Cheers
Ian
2016-5-10
Aardvark
Flight distance : 384432 ft
You wouldn't be running short of memory on your device ?
2016-5-10
PhanFran
Flight distance : 4804163 ft
Belgium
On my iPad Air 2 DJI GO asks me if I want to use cellular data to load the maps or not. I guess using Google Maps 'offline' can not and will not load all the regions of the world, so you will always need an Internet connection when you go a bit further than your backyard.
2016-5-10
Aardvark
PhanFran Posted at 2016-5-10 22:02
On my iPad Air 2 DJI GO asks me if I want to use cellular data to load the maps or not. I guess usin ...
A degree of truth there, but if you scan over the areas you plan to visit from home when connected to wifi then it 'should' buffer the images in memory.
In the 'General Settings' menu ' Cache Map in the background' switched on, should provide just that.
2016-5-10
wellsi
That's not the case, as many cellular devices have an 'either / or' setting for wi fi and cellualr data, meaning you have no internet if you're connected to the phantom's wifi.
But that's not the point; this used to work perfectly until around a month ago.  Until the last update thinking about it......
I'll check the memory, but the actual offline maps file has downloaded fine as it works if I open up google maps when I'm not connected to the internet.
Ina
2016-5-10
DJI-Paladin
Flight distance : 2408 ft
Hello wellsi, what's the app version in your android device?
2016-5-10
wellsi
DJI-Paladin Posted at 2016-5-11 07:55
Hi Paladin
The GO App is Android 2.8.0
I'm running it on Android 4.4.2
Thanks,
Ian
2016-5-11
PhanFran
Belgium
wellsi Posted at 2016-5-11 08:36
That's not the case, as many cellular devices have an 'either / or' setting for wi fi and cellualr ...
OK, but while my P3 or my P4 is flying far away from any wifi I can receive e-mails and see websitres. I guess that these come in through cellular. Don't know how the P3S is controlled thouigh so might miss something here.
2016-5-11
DJI-Paladin
wellsi Posted at 2016-5-12 03:56
Hi Paladin
Please try to play back the flight record with your device connecting to internet service.When there isn't any map cache in your device and it keeps offline, it will show "Map Loading".
2016-5-12
wellsi
DJI-Paladin Posted at 2016-5-13 03:14
Please try to play back the flight record with your device connecting to internet service.When the ...
Hi Paladin
I don't understand why I now have to do this now? I thought the whole point of cached maps was that you can fly using them without internet connection.
Up until a few weeks ago, the cached maps worked fine on my tablet, during the flight, with no internet.  That's how I could see the position of the drone when flying.
Now those cached maps are being ignored by the App. So instead of seeing the high detailed map, I get a blurred or blank map.
Has the function of 2.8.0 changed to ignore cached maps, or is there a setting issue that I can rectify?
Cheers
Ian
2016-5-12
DJI-Paladin
wellsi Posted at 2016-5-13 14:21
Hi Paladin
I don't understand why I now have to do this now? I thought the whole point of cached m ...
I think you may need to connect to Internet when you check the record for the first time and make sure the map has been cached in the app.
2016-5-12
nigelw
Flight distance : 518084 ft
DJI-Paladin Posted at 2016-5-13 07:35
I think you may need to connect to Internet when you check the record for the first time and make  ...
I think his problem isn't with the map in playback.  It's not having the cached map available while flying out in the field where it's needed.
2016-5-13
wellsi
Hi again Paladin
The issue is that the maps do not work at all.  Not when I'm flying; not after when I look at the logs.  Up until a few weeks ago, they did work fine.
I have never had to connect to the internet to see the maps; that's the whole point of cached offline maps.
What changed in 2.8.0?
2016-5-14
DJI-Paladin
wellsi Posted at 2016-5-14 16:05
Hi again Paladin
The issue is that the maps do not work at all.  Not when I'm flying; not after w ...
As far as I'm concerned, the 2.8.0 app doesn't change the map cache function."Map loading" in viewing flight record was a known issue in the previous version but it has been solved now.So I'd suggest you to reinstall the app and then cache the map with Internet service again.Don't forget to synchronize the flight record before reinstalling the app.
2016-5-14
GWinford
same with me, no maps on all upgraded devices
2016-12-26
C. Dave Pappas
Flight distance : 223468 ft
Same with me as well. The satellite imagery worked very well when I first got my P4 about a month and a half ago, now it don't work at all.
2016-12-26
Geebax
C. Dave Pappas Posted at 2016-12-27 08:31
DJI have changed map providers to 'Here' maps, and the result is pretty useless.
2016-12-26
C. Dave Pappas
Geebax Posted at 2016-12-26 17:35
Maybe it's time to sell this thing and build my own bird. Less restrictions and forced changes.
2016-12-26
Aardvark
Geebax Posted at 2016-12-26 22:35
'Here' seems to be on Android only, IOS still using its own mapping system, data provided by TomTom (and others).
2016-12-26
Bayguy69
Flight distance : 944275 ft
Puerto Rico
Aardvark Posted at 2016-12-26 21:21
That's one of the reasons I love my iPad Air 2 with my P4
2016-12-26
elmt136-sp
Flight distance : 7946 ft
I have tha problem in my p3 advanced i need to fixed
2016-12-27
