How does max radius work?
1311 5 2015-1-18
Capt. Bill
In the vision assistant you can set a max range and it can be as low as 33 feet.
Let's say you set it to 50 feet and fly straight out away from you. What happens when you reach 50 feet. Does it act like you had a 50 foot string attached to it and just stop. If you gave a command to move to one side at a 90° angle would it travel in arc, again just as if it had a 50 foot string attached.
2015-1-18
markus2015
If it reaches the border of your set range, it will stop moving in that direction and not fly further. Just tray it out, nothing should happen. It acts like a circle or dom (if height is also set to xx feet) around your homepoint.
2015-1-18
Capt. Bill
markus2015 Posted at 2015-1-19 02:18
If it reaches the border of your set range, it will stop moving in that direction and not fly furthe ...
From the diagram I think it is more like a cylinder than a dome. If max radius was set to 50 feet and max height set to 200 feet, it would be like it was connected to a 50 feet string that could move up and down 200 foot pole.
2015-1-18
markus2015
yeah, sorry, that's what I meant to say. My english is not perfect.
2015-1-18
fans829ed18c
markus2015 Posted at 2015-1-18 11:18
How far is the radius set to in "Beginner" or Default mode?
2016-12-25
Aardvark
Flight distance : 384432 ft
fans829ed18c Posted at 2016-12-25 17:07
30 metres (98 1/2 feet) in beginner mode.
2016-12-27
