bornish
Flight distance : 91447 ft
I recommend a Joby Hub Adapter.
It can be used as is, but I have personally modified it to perfectly be used with all DJI accessories.
I had purchased 2 straight arm extenders from DJI and was quite unhappy how bulky the setup become when attaching multiple accessories. Since I am using quite often at least one more than the mobile holder, I could never use only one straight arm extender while also mounting the whole setup (tripod, bike mount, ...) .
It took a day's work to modify by combining the parts I have purchased, but was quite easy to achieve by cutting 1 straight arm extender. I have used a Dremel for cutting, polishing and drilling, so pretty much anyone can do this in their home.
Now, even for the most complex setup, I can securely attach all possible accessories to the OSMO and mount everything on any type of mounting just by using 2 Joby Hub Adapters and 1 straight arm extender.
If others are interested, I am willing to post some pictures of the parts used and different mountings and accessories combination.
Best regards,
Bogdan |
