Converting dji fix (djifix.exe) repaired video files
13114 9 2016-5-11
mackswell
So shout out to user Geebax for pointing me to the djifix.exe application which will repair corrupted video files...  For those of you who don't know, if you power off your drone before stopping the video recording, the file will be corrupt.  This has happened to me before, but this was not the case this time around.  This time, my microSD card failed on me and wouldn't mount.  I used CardRescue ($40 on Mac) and was able to get the files... but one file was unplayable until I ran the djifix.exe application!  Voila!
Here is the djifix.exe for those looking for a solution to their own corrupt video file problems: http://live555.com/drones/DJI-Phantom-2-Vision+-video-fix/
After putting in a few lines of code in Terminal, you end up a few minutes later with a file like this: File0003-repaired.h264 which is only playable on VLC.  It is really reassuring to be able to open up the file and see it's all there.  THAT being said, I can't do anything with this bizarro .h264 file the djifixe.exe application produces.
Does anyone know a surefire way to convert the .h264 file back to .MOV or to .MP4?  I have tried Miro Video Convereter and Win X Video Converter for Mac, and no dice.  Neither programs will even load my file!
Thanks so much,
Mackswell
2016-5-11
Geebax
Perhaps you might try Handbrake, it is one of the most valuable tools around: https://handbrake.fr/
2016-5-11
mackswell
Geebax Posted at 2016-5-12 07:08
I've tried this as well... no luck so far.  Thanks again for your help.
2016-5-11
Geebax
mackswell Posted at 2016-5-12 09:22
Perhaps if you could post the file to Dropbox I, or others, may be able to try to use it, then report back.
2016-5-11
mackswell
Geebax Posted at 2016-5-12 07:28
Perhaps if you could post the file to Dropbox I, or others, may be able to try to use it, then rep ...
Thanks so much for the kind offer.
As it turned out, I was able to get Miro Video Converter to work after all!  The UI went completely bananas when I started the conversion and nothing happened (the Miro application appeared to be frozen) but I noticed my CPU ramped way up... and Activity Monitor's top task was ffmpeg so I put two and two together.  Waited a little longer and boom there it was!
So that's the solution:
dji fix (djifix.exe) + Miro Video Converter + a little bit of patience = repaired files
Thanks for all of your help Geebax.
2016-5-12
grzegorz
Poland
hi!
i have problem with this file:
https://www.dropbox.com/s/enbpnwaxksz5daj/bad.MOV?dl=0
i try djifix, recover_mp4_to_h264 and power on phantom inc card. no lucky.
eny ideas? help please.
2016-5-22
grzegorz
Poland
grzegorz@sgf.pl Posted at 2016-5-22 15:14
hi!
I forgot:
Phantom 3 adv, 23,9 fps, 2,7k, mov
2016-5-22
mackswell
grzegorz@sgf.pl Posted at 2016-5-23 00:57
I forgot:
If you run djifix.exe, you will end up with a file like File0001.H264. Download Miro Video Converter to convert that file to .mp4. It may stall and take a while, but it will work.
As far as the card goes— if you're like me, you may have ruined the card.  You will need to reformat it (preferably to exFAT) in either your P3Adv or in your computer before it will work again. I wasn't able to reformat my card, so had to toss it and get a new one.
2016-5-24
grzegorz
Poland
Unfortunately DJIFIX does not work as it should. It creates a file h264, but is 0 mb.
I received a file h264 by rocover_mp4_to_h264 - It has data (the same as the original mb), but it has only a single frame.
The conversion from h264 to mp4 does not help.
2016-5-25
djiuser_rfVUVc2EiIz6
Worked like a charm: same problem , video interupted during landing through abrupt powerdown, I downloaded djifix, ran in on windows using the cmd, used the M paramameter when called for and converted it using the VLC utility. What a great fix, I got the video back from my maiden flight. THANKS!!!
2020-10-24
