Just bought Litchi App but won't connect!
20991 24 2016-5-13
G_MEZ_G
Anyone had this happened? I bought the Litchi App and it says disconnected. Not sure what to do to make it work. I tried on my iPhone 6+ and iPad Air 2. Any suggestions? Also the DJI Go App is working fine.
2016-5-13
vu.q.le
Banned
2016-5-13
Boblanglois52
Flight distance : 129567 ft
I don't have any trouble connecting without the Go App running. I just set wifi to the drone and it connects. I haven't flown with it yet due to bad weather in New Hampshire. I use an Android phone, by the way.
I just copied this from the Litchi Manual
  1. Why is Litchi not connecting to my Phantom 3/Inspire 1?
                                         When starting the app for the first time, you will need to be connected to Internet in order to validate the app with DJI servers.
Some Internet connections may have troubles connecting to DJI servers, in such a case make sure to try a different Internet connection.
                                         Additionally, on Android if DJI Go is your default app for the remote controller USB connection, you will need to clear the defaults for DJI Go (Settings -> Apps -> DJI Go -> Clear Defaults).
2016-5-13
rayrokni
Flight distance : 8139875 ft
I have exact same setup with a P3, and it works great. And no I don't run go app first, I connect using litchi no problem.
What phantom do you have, what versions of fw.
When you installed the litchi and ran it the first time, did you click on "allow" to all the pop up screens that came up?
You can try this: with the AC and RC both on, shut down the app, unplug cable, replug cable, start litchi app and see what happens
2016-5-13
G_MEZ_G
rayrokni Posted at 2016-5-13 18:50
I have exact same setup with a P3, and it works great. And no I don't run go app first, I connect us ...
P3P LATEST FW
2016-5-13
bfd300
Flight distance : 73661 ft
That's weird......Litchi works just fine w/ my Ipad air 1 and my iphone 5c. try deleting the App and re-installing.... For giggles try a diff cable.
2016-5-13
rayrokni
Did you try what I said
2016-5-13
G_MEZ_G
So I tried connecting the go app first and it worked. Not sure if it was related to that or not because I also noticed an email from Litchi asking to verify my email address
So after using it, I have to say I'm not impressed. I could not get a good lock on something for tracking and it would freak out when it lost the object. There was a point that the P3 would not even respond to my commands on the joysticks. I can live without the app.
2016-5-14
MTR-Aerial
Is the point and track supposed to work with the P3-S as well?
2016-5-14
G_MEZ_G
MTR-Aerial Posted at 2016-5-15 02:36
As far as I know, yes.
2016-5-16
MTR-Aerial
G_MEZ_G Posted at 2016-5-17 00:35
Thank you sir!
2016-5-16
spencerbent
Had the same problem not connecting to Lichi app. Solution that fixEd my problem was to remove DJI GO from  the default program. Even if I force closed both apps and loaded lichi I had no luck until I did the avove.
2016-5-28
BillDrum
Has anyone using DISHNET  been able to connect to DGI servers?
2017-2-15
Anonymous1
Flight distance : 602303 ft
Jamaica
I have the same issue with this on my Note 8 running the latest firmware on my Phantom Standard 3
2018-9-3
Anonymous1
Jamaica
Boblanglois52 Posted at 2016-5-13 15:37
The "Defauts" option is greyed out for both DJI Go and Litch.
DJI Go continues to work perfectly.  I just wish to do Waypoint missions using Litchi.
2018-9-3
Anonymous1
Jamaica
spencerbent Posted at 2016-5-28 19:44
How do you do that?  My Note8 shows the Default option greyed out in the SETTINGS menu in my phone.
2018-9-3
RicardoGray
Flight distance : 4356421 ft
Anonymous1 Posted at 2018-9-3 09:58
You should be able to go into the settings, then into the apps. Scroll though your apps until you get to DJI. Now tap on it and it should open up the settings for that app. Look through the list and you should see something like "Open by default". Click on that and clear the default settings. Do the same for Litchi. Now when you have your RC on, and your phantom on, then plug your usb cable into your device, it should now prompt you which one to use. Always pick "This time only". Do not pick "Always". If you do by mistake, just go back and clear those defaults so it will ask you each time.
So, is this where you are trying to go, and are you saying yours is grayed out and you cannot clear it?
You need to go into the DJI app itself, not the default programs if I understand you cprrectly.
Hope this helps.
2018-9-5
Anonymous1
Jamaica
I have the Phantom 3 Standard, so I don't have the luxury of connecting my phone to the RC transmitter using USB (like the Pro or Advanced models).
The DEFAULTS option is greyed out on my phone for both the DJI GO and Litchi.  I suspect that ultimately, I'll have to delete DJI GO to use Litchi, but I don't want to do that and lose my flight logs (and the user friendly interface of the DJI GO app).  My other test later would be to just install Litchi on another device (only) and use that permanently for Litchi.
The Settings option in the ME option of the DJI GO app doesn't give me any "defaults" option in the Privacy menu.
2018-9-5
RicardoGray
Anonymous1 Posted at 2018-9-5 06:11
I think you may not be followling my suggestion. It is not necessary to connect to your RC to remove the default settings for the app. I am not familiar with your device, but I have had multiple android devices (which I think your is), and all are the same as I described. I might suggest loking on the internet for your answer. You need to have the GO app to set some settings on your aircraft. I understand what you are thinking, but there isn't any reason you can't have both apps on your device. Un-installing the GO app will not cause you to lose any information. It normally doesn't delete all files such as flight logs, etc. When you re-install the app you should still have most of that. You may have to re-set the settings in the app itself as fa as any camera settings. Normally after the install, and you have both apps installed, when you connect to the RC with the app, it should ask you which app you want to use. Just pick "This time only", or "just once"......something like that. Do not pick "Always". Sorry I can't offer any more to help you. Hope you get it working for you.
2018-9-6
Anonymous1
Jamaica
I'm not actually connecting to anything (transmitter or Pahantom3) when I try your suggestion.   I'm just telling you that my "defaults" option is greyed out (unselectable) on my Samsung Galaxy Note 8.
I've never gotten the option to pick "This time only", or "just once" on my phone.  I even uninstalled the DJI GO app, tried with Litchi installed only, but it didn't work.
When I just purchased the Litchi app, it connected to my Phantom 3 once, but since I restarted the app, it didn't reconnect again nor show me the "This time only", or "just once"
2018-9-6
RicardoGray
Anonymous1 Posted at 2018-9-6 16:30
OK, I'm sorry for your troubles. I understand now what you are doing. It is strange for sure. Not sure what else to offer up. Seems odd it would open the app once, but not again??? Only thing I can suggest is again to maybe google your issue for your device. I have never seen your issue myself. There must be some setting turned off not allowing you to change those default settings. Best of luck.
2018-9-10
Bashy
Flight distance : 2354357 ft
Hi, have you tried going to settings, then apps, then 3 dots top right, choose default apps, then remove DJI go as the default app. then see which connects and if all is ok DO NOT TICK make default
2018-9-10
Anonymous1
Jamaica
My Samsung Galaxy Note8 has the DEFAULTS option greyed out.
The Litchi app NOW allows me to connect with the Phantom 3's camera, but will not allow me to unlock the motors. It however updates gimbal movement and what the camera is seeing in real time.
The DJI GO app continues to work as usual.
2018-9-25
KenDuke
Flight distance : 61175 ft
You must be running a old version of Litchi.  Update via the Play store.  The newest one works great on both iOS and Android.  Running iOS 12.1 and I've tested on Android 7.1.1 and 9.0(Pie)
2018-10-13
Anonymous1
Jamaica
I can tell you that my version was up-to-date even as recent as last week from the Google Play Store.  I can now see only the static image that the camera shows, but and arm my Phantom 3 standard, or actually deploy a saved flight mission.   I can arm the PS3 directly using the stick commands, and fly line of sight, but it doesn't reflect anything in the actual Litchi app itself.   The DJI GO app still works great just the same.
2018-11-12
