labroides
![](https://forum44.djicdn.com/data/attachment/common/c8/common_2_usergroup_icon.png) Core User of DJI
Flight distance : 26781877 ft
"Today I got my first compass error, and of course it was during my first flight over water. ... got compass errors when i went over the water, then i brought my controller on top of the picnic bench and it switched back to p-gps."
As you now know, the compass error refers to the compass in your Phantom.
That you got a compass error showing up when you flew away from land to water strongly suggests that you calibrated in a bad area where the earth's normal magnetic field was distorted by some steel.
The mention of a picnic bench is suspect bit it might have been that you calibrated close to a car or reinforced concrete etc.
When you flew away from the magnetic influence and becah to the earth's normal field, your compass which has been corrected for the extra magnetic effect, now is reading wrong.
That's when your Phantom alerts you that the compass is reporting that something's wrong.
If you have to calibrate your compass (and you shouldn't have to very often) never do it anywhere near cars, structural steel, buried pipes, reinforced concrete etc. |
