Probs lock.READ THIS ,SAVE YOUR BIRD!
12Next >
3343 40 2016-5-16
karlsbar
Please check the small P4 Plastic Probfastlockthings on your Birds and stay secure the screws are strong mount.
I habe checked this today bevor start an one of this importand things was a bit loosen.
Check this bevor Start of proper mount and in good condition.
Hold the Motor and take the plastic right and left to check is it good mount and screws are fit good.
Or is remount with "Loctite" better is the Question for DJI?!
Lose a Prob in Air is a horror !
greets
a old man
2016-5-16
Remco
Flight distance : 56381 ft
Thanks,  i checked mine and 2 out of four where a bit loose.
2016-5-16
visitkans
Flight distance : 80413 ft
There was a thread yesterday of a crash and it looked like the plastic mount had come off mid flight..
2016-5-16
karlsbar
visitkans Posted at 2016-5-16 22:25
There was a thread yesterday of a crash and it looked like the plastic mount had come off mid flight ...
I have it read and now i'm very carefull with my bird.Endcontrol issues are the problem i think.
2016-5-16
SajidShah
Flight distance : 627539 ft
Portugal
ur right cause quick released plastic is damaged many times
2016-5-16
karlsbar
SajidShah Posted at 2016-5-16 23:34
This is i think an effekt  when Probs are taking the ground or other .
Change it on contact with any things there are not Air!
I have Spare Part No 51 allways in pocket but only four of six screws have the blue glue that take the screws are secure.Endcontrol is the issue,i think.
Small plastic big effekt.
Loctite is my new Friend.
2016-5-16
Philj6970
Flight distance : 840663 ft
Palestine
Thanks for this information.
I just checked my P4 which has less than 4 hours flying time on it.
One of the 4 prop holders was slightly loose, probably less than 0.1mm play, but it had enough to feel a slight click when rotating the prop holder while holding the motor.
I tightened the three screws a little until the play had gone.
2016-5-16
desta
Flight distance : 948858 ft
i checked mine and one was a tad loose as well (will check them from time to time now) i only have around 10hrs on mine
2016-5-16
hungdang
Flight distance : 4931706 ft
Thanks for your info. I have checked my phantom 4, the front right mount was loosen so i have tightened it
2016-5-17
Nelsongc1
Take a fine permanent marker and make a line across the screws and plastic.   We do this on aircraft to have a visual inspection to see if the screws are coming loose.  It's called torque stripes.
2016-5-17
tomkes
Switzerland
A picture of the screw or whatever it is called to be tighten would be helpful.
Thanks and regards from Switzerland
2016-5-17
timmer1
Flight distance : 30502 ft
Do not use Loctite on your Phantom.
There have been many reports of it melting the plastic.
2016-5-17
visitkans
Nelsongc1@msn.c Posted at 2016-5-17 13:43
Take a fine permanent marker and make a line across the screws and plastic.   We do this on aircraft ...
Very nice tip, love this,
Have ordered the loctite threadlocker, will apply that and have the lines made.
2016-5-17
visitkans
timmer1 Posted at 2016-5-17 14:11
You do t put loctite on the plastic, i guess its the loctite threadlocker blue thing to be used on the threads, its quite common in rc toys
2016-5-17
malvern
What tool do you use to tighten the screws ? And what size ?
2016-5-17
visitkans
malvern Posted at 2016-5-17 14:56
1.5mm hex allen key
2016-5-17
malvern
Thanks for that.
2016-5-17
nrechtman
Flight distance : 1555344 ft
Yes some pictures would be great
2016-5-17
visitkans
The 3 screws you see there that holds the white plastic in place, that can loosen over time due to vibration
2016-5-17
techmyjustin
Flight distance : 191896 ft
visitkans Posted at 2016-5-17 23:12
The 3 screws you see there that holds the white plastic in place, that can loosen over time due to v ...
Thanks for the picture, this helps!
2016-5-17
Cale262
Great post, thanks OP! 96 flights with my P4 and it never occurred to me to check those. Upon my inspection I found 3 loose screws and snugged them up but it will be part of my regular routine and I also marked the screws with a sharpy thanks to Nelsongc1 so this will be an easy visual inspection...another thing I do on all my vehicles when wrenching on them but also never occurred to me to mark my birds screws....
Cheers!
2016-5-17
Nelsongc1
I believe that it is a good idea to replace the proper holders and props after 25-30 hours of flight.  They are plastic and probably take a lot of abuse taking them on ond off as well as in flight which can develop micro fractures that can't be seen.  They are 3 bucks per pair from DJI and cheap insurance.   I'm thrilled with my Phantom 4 and tightening and checking all the components is part of the hobby, no bird is maintenance free.
2016-5-17
Cale262
Nelsongc1@msn.c Posted at 2016-5-17 16:43
I believe that it is a good idea to replace the proper holders and props after 25-30 hours of flight ...
I was actually thinking about every 100 flights which at 20 minutes a flight is about 30hrs which I'm close to now. I bought a bunch when they came out just to have them when the need arose.
2016-5-17
Cale262
Double post...
2016-5-17
Nelsongc1
Cale262@gmail.c Posted at 2016-5-18 07:00
I was actually thinking about every 100 flights which at 20 minutes a flight is about 30hrs which  ...
That sounds like a good number.  They come with new screws as well which is nice as well.
2016-5-17
jstjohnz
Flight distance : 1146388 ft
I found one loose as well.  A warning to periodically check the tightness of these screws should be in big bold letters in the DJI docs.  If this was the cause of that recent 'lost prop' crash, and the problem is as common as it seems to be, I expect there will be more crashes.
2016-5-17
projeffrey11
Thanks mate.
2016-5-17
tomkes
Switzerland
I checked them. No one was loose, but all were not very strong  thighten
2016-5-17
Cale262
Nelsongc1@msn.c Posted at 2016-5-17 18:17
Yes they do come with new screws and I can see that each screw comes with blue loctite on the threads, maybe something they didn't come with one some birds from factory.
2016-5-17
sl44er
Less than one hour flight time with P4 and five screws were lose on three motors.    One screw required 1.25 turns to correctly tighten and no I did not over torque prop mounting plate screws.   Will add check prop mounting plate screws to preflight list.  Thank you!    Why is this required routine maintenance excluded from DJI documentation for safe operation of aircraft?
2016-5-17
Moshe.mmm
Flight distance : 1320098 ft
Israel
What do you think about these :
http://s.aliexpress.com/ZvUR36b2
2016-5-17
Moshe.mmm
Israel
I received update from one of the dealers that the carbon fiber propellers for p4 are still mature and not stable.
2016-5-19
sivaneswaran.sa
Flight distance : 339888 ft
thanks for this
gonna check mine today
2016-5-19
simon
Flight distance : 191998 ft
Would like to add to the screw loose debate that I had 2 screws over 1 turn loose with 3 others starting to loosen with less than 5 hours flight time. Well done OP for bringing attention too it. I appreciate it is a tight line between too much thread lock and too little.  A touch more perhaps DJI as the overall locking system and improved safety of the completely snapping props in impact is excellent. Be a shame to have to change it because of a few screw loose incidents.,
2016-5-19
keongwee85
Flight distance : 331391 ft
Malaysia
Hi guys, useful thread. However was wondering about internal, inside the drone do we open it up to check if there is any cable that gone loose etc ?.??.
Regards,kw
2016-5-19
jaraxle1zx
All mine were loose.
Thx for posting this thread
2016-5-20
c.davies60
Checked mine and thankfully no movement. Will be carrying allen keys about from now on though.
2016-5-21
Moshe.mmm
Israel
Hi,
What about if the propellers holder is solid and has no freedom when trying to move it left and right when holding the motor, but when attaching the propeller and trying to move it left and right when holding the motor steady,
The propeller itself has some freedom..?
Is it dangerous?
3 of the propellers doesn't have freedom and and one dose.
Did it happen to you too?
2016-5-29
ville.honkonen
Flight distance : 80919 ft
Finland
All 4 was loose.. thanks for the tips.
2016-5-29
jameswarden
Just checked mine and found two loose after only 3 flights. So will also make this a regular check.
2016-5-29
12Next >
