I give up, can someone please help?
The_droneMan
Norway
I have been trying to get my S1000+ up in the air for 5 days now, im on the point of giving up.
S1000+
A2
LB2
Z15 A7
22000MAH Tattu  Battery
I get flashy red lights which dont stop. I have tried calibrated it a thousand times, still red blinking lights. In the A2 assistants it says update the GPS, but the GPS is updated. I get GPS signals and satelites and it works perfectly inside the DJI GO app. I have tried other batteries of the same type, still doesnt work. Is the battery messing something up? Is the compass broken? What is the problem. I have no clue and soon giving up. The Motors wont start ofcourse.
2016-5-17
DJI-Adela
Hello!
As showed in your picture, the firmware version of your GPS module is not the latest. Could you please download the latest A2 Assistant Software 1.9 to upgrade it again?
For more relevant information, please refer to http://www.dji.com/product/a2/info#downloads
Thanks.
2016-5-17
The_droneMan
I had the latest version A2 assistant 1.9. just to be sure I uninstalled it and downlaoded it again.
And yes, The IMU is connected to the CAN1 port. THE a2 PMU is connected to CAN2.
2016-5-17
The_droneMan
As you can See. There is some weird thing going on with the firmware? It asks me to install from 2.7 to 2.7..
2016-5-17
DJI-Adela
The_droneMan Posted at 2016-5-17 17:27
I had the latest version A2 assistant 1.9. just to be sure I uninstalled it and downlaoded it again. ...
Have you upgraded all modules to the latest versions?
Please show us all the firmware versions in Info menu.
2016-5-17
The_droneMan
The_droneMan Posted at 2016-5-17 17:37
As you can See. There is some weird thing going on with the firmware? It asks me to install from 2.7 ...
I want to try to reset all firmware and update again? How do I do that. That might solve the problem
2016-5-17
DJI-Adela
The_droneMan Posted at 2016-5-17 17:50
I want to try to reset all firmware and update again? How do I do that. That might solve the probl ...
Hi,
Please try below hard reset method:
1). short-circuit the F1/F2 ports via a 3-PIN cable (see below picture).
2) Connect to main controller to the assistant software as usual. Click “upgrade” and the system will download new firmware automatically.
3) After the download has been completed, please pull out the 3-PIN cable and then click “upgrade” again. Otherwise, upgrade will fail.
2016-5-17
The_droneMan
DJI-Adela Posted at 2016-5-17 18:01
Hi,
1). short-circuit the F1/F2 ports via a 3-PIN cable (see b ...
Still the same.
2016-5-17
DJI-Adela
Hi,
Are you using GPS Pro or GPS Pro Plus?
Wait for your reply.
2016-5-17
The_droneMan
DJI-Adela Posted at 2016-5-17 18:56
Hi,
It says on the GPS : "GPS-Compass Pro"
2016-5-17
The_droneMan
Here is my wiring Setup
2016-5-17
The_droneMan
Here it is....
2016-5-17
The_droneMan
Norway
Is it possible to reset firmware for the IMU and the GPS ?
2016-5-17
fieldsmdavid15
Flight distance : 687995 ft
The_droneMan Posted at 2016-5-17 19:22
I do not think it is.
2016-5-17
dennismurry08
Flight distance : 5948264 ft
Once you get your compass worked out, may I also point to a potential issue? Your assistant shows your first level battery protection at 11.1 and second at 10.6. You should have first around 21.8 or so and second around 21.5...everybody has a different opinion but if you rely on the led for battery warning then you are crashed at around 20.5V.
2016-5-17
rodger
Flight distance : 20145135 ft
You are way above my pay grade!
2016-5-17
DJI-Adela
Hi,
May I bother you to show me the interface showing all the firmware versions together for all the modules?
Thanks.
2016-5-18
The_droneMan
Norway
SOLUTION:
I found the DJI A2 Assistant v 1.8 and downloaded it.
took the 3 pin cable method, reset the firmware and installed the 2.6 firmware.
Everything works fine
2016-5-18
DJI-Adela
The_droneMan Posted at 2016-5-18 23:27
SOLUTION:
took the 3 pin cable method, reset ...
Great!
Thanks for your feedback.
2016-5-19
