visitkans
Flight distance : 80413 ft
Here is what i did
The process is...
heat water to around 80 degree C, mix the dye in it, and in a tray or bottle, immerse the props and let it stand for 2 hours, if you want a deeper colour, keep it in for longer.
Some cook the props in hot water to reduce the time, but i was a bit scared that i might deform them, so kept it longer in hot water.
Black was the longest, took 20 hours, it turned blue to dark blue and then black.
Deep orange is 8 hours.
As you see its quite easy to do it, if you dont mind waiting longer, then warm water and overnight dipping and you should be good. |
