Gimbal Motor Overloaded
918 4 2016-5-18
k.lower
Can anyone suggest what is going wrong with the gimbal, it seems to be getting worse
2016-5-18
mrbill
Flight distance : 717100 ft
Try an IMU calibration, followed by a gimbal calibration, if you haven't done that already
2016-5-18
connorschulte
Flight distance : 261033 ft
mrbill Posted at 2016-5-18 10:11
After you calibrate, take a flight.
If the problem still occurs, upload your flightlogs to http://www.healthydrones.com/ so we can take a look.
2016-5-18
Visual Air
Flight distance : 715338 ft
I think it has something to do with the sport mode the gimbal cannot handle the force generated by flying in sport mode...
What else could it be and the only answer you will likely get is to send it in for repair
2016-5-18
DJI-Paladin
Flight distance : 2408 ft
Hello k.lower, does this issue happen when the drone is hovering or flying in P-mode?
2016-5-19
