johnwarr
Flight distance : 6467 ft
Firstly are you in Phantom or NAZA mode ?
When you flip the switch to calibrate the compass the rear LED's go solid Yellow ?
Then after you rotate horizontally they go solid Green, then after you rotate vertically (nose down) the rear LED,s should flash Green / or Yellow or Red / Green depending on what mode you are in.
Flashing Green is GPS locked.
Solid Green means that you have not finished the compass calibration.
Maybe hook up to the PT2 assistant and see what the compass readings are, they tell you what range it should be. |
