Filter for PH3 and PH4
1809 13 2016-5-18
tomkes
Switzerland
Is the PH4 camera using the same filter sizes like used for the PH3?
For the PH3 i find tons of different ND filters but only few for the PH4.
Thanks and regards from Switzerland
Tom
2016-5-18
DJI-Paladin
Flight distance : 2408 ft
Hello Tom, they are using the same size filters.
2016-5-18
Moshe.mmm
Flight distance : 1320098 ft
Israel
Is it possible to put 2 different filters together?
2016-5-19
phantom-four.co
As mentioned before, they are compatible. The only thing to keep in mind that they P4 gimbal guard may not fit (try it first) with the filters you have.  If it indeed doesn't fit then you can look at replacing it with the PolarPro Lens cover/gimbal guard instead.
2016-5-19
connorschulte
Flight distance : 261033 ft
Moshe.mmm Posted at 2016-5-19 08:35
Screw-On Filters, no. Maybe if it clipped on but there's no reason to have 2 filters on.
2016-5-19
PolarPro
Flight distance : 315682 ft
Hey Tom!
Our filters have slight differences. The camera barrel on the P4 is slightly longer, so we made a new filter for the P4 that fits perfectly flush. The P3 filters will work and thread on, however there will be a small gap between the camera and the end of the filter.
Let me know if you have any other questions!
Jeff
2016-5-19
Nelsongc1
I bought a new gimbal lock from dji and cut off the front face which allows for the length of the polar pro filters.  It still cradles the camera firm and I don't have to take the filters on and off.
2016-5-19
tomkes
Switzerland
Thanks to all,
i already ordered the Polarpro 3 filter set specially designed for the PHP4.
Yesterday I unscrewed the original lens filter which was not easy and I was scared to break the Gimbal.
My recommendation to DJI please screw the lens filter with any lower torque.
Regards from Switzerland
tom
2016-5-19
Moshe.mmm
Israel
connorschulte Posted at 2016-5-19 20:02
Couldn't be a reason to use nd and cpl at the same time?
2016-5-20
PolarPro
Moshe.mmm Posted at 2016-5-20 21:17
The main reason you would not want to stack filters is the added weight. It would be too heavy for the Gimbal. We make single element ND/PL combo filters for that reason, they are same weight as the single filters to ensure smooth gimbal operation.
Jeff
2016-5-20
Moshe.mmm
Israel
Thanks for the info.
Can I have a link for these combo filters please?
2016-5-21
mmarkoe
Flight distance : 15135 ft
Moshe.mmm Posted at 2016-5-21 16:02
Link for Cinema Neutral Density/Polarizer Filters
2016-5-21
Moshe.mmm
Israel
Thanks.
I'm not sure which set should I go for.
The cinema vivid look more suitable for me because its with pl but I doubt nd16 would be enough for our summery sun..
Is the a possibility to mix from the two sets?
Thanks.
2016-5-21
PolarPro
Moshe.mmm Posted at 2016-5-22 12:11
Thanks.
The cinema vivid look more suitable for me because ...
I personally use the Cinema Series 90% of the time, but you are correct, if it is very bright out you might need the ND32 or even the ND64.
Shoot me an email and I can get you a custom set built!
Jeff.overall@polarprofilters.com
Thanks Moshe!
Jeff
2016-5-23
