Remote version differences?
1582 15 2016-5-19
Michael M
Flight distance : 1984898 ft
What is the difference between the GL300B version of the remote and the GL300C?
@Dji Dave or anyone know?
2016-5-19
DJI-Paladin
Flight distance : 2408 ft
They have no difference in operating the aircraft.
2016-5-20
Michael M
DJI-Paladin Posted at 2016-5-20 16:56
then why is there a c version? What has changed?
2016-5-20
DJI-Paladin
Michael M Posted at 2016-5-21 15:05
Just the manufacturing batch is different
2016-5-20
Michael M
DJI-Paladin Posted at 2016-5-21 15:21
I heard it has lowered output power. Is that true?
2016-5-20
Michael M
Michael M Posted at 2016-5-21 15:29
I am getting weak image signal much more often than before with my old remote
2016-5-20
DJI-Paladin
Michael M Posted at 2016-5-21 15:30
Did you try to adjust the RC or antenna's position at that time or fly the drone in another position?Do you use the same drone to fly?
2016-5-21
ranges
There are several differences. Here is a link with an explanation:
http://forum.dji.com/thread-24446-1-1.html
You can probably google some more threads on this.
2016-5-21
ranges
Michael M Posted at 2016-5-21 03:30
You and a lot of other people
2016-5-21
Aardvark
Flight distance : 384432 ft
Michael M Posted at 2016-5-21 08:05
Well hopefully the internal build has improved, some of the GL300Bs were poorly constructed. With self tapping screws into cracked plastic pillars with stripped threads. Hence all the disappearing RTH buttons & control sticks. The GL300C has the metal support bracket for the device holder which is much more substantial than the plastic one. And as I said I 'hope' better build inside.
2016-5-21
Aardvark
I also did a ground test in built up area on my previous P3P & GL300B, left copter sitting on its box in garden then walked down road with transmitter, with only one or two glitches on video as I walked as far as I could in line of sight, which was about 2,500ft before I ran into a brick wall . I did a similar exercise with P4 & GL300C and achieved very similar results.
As far as I remember both were showing full bars for control & video at furthest point.
2016-5-21
Michael M
Aardvark Posted at 2016-5-21 18:58
I also did a ground test in built up area on my previous P3P & GL300B, left copter sitting on its bo ...
Glad to hear. Thanks!
2016-5-21
Michael M
DJI-Paladin Posted at 2016-5-21 16:35
Did you try to adjust the RC or antenna's position at that time or fly the drone in another positi ...
Same drone same conditions. Do you know the output of the remote? Is it the same for both?
2016-5-21
Michael M
ranges Posted at 2016-5-21 18:12
http://forum.dji.com/thread-24446 ...
Thanks
2016-5-21
Michael M
Aardvark Posted at 2016-5-21 18:49
Well hopefully the internal build has improved, some of the GL300Bs were poorly constructed. With  ...
Bith two moodels ive had are plastic support brackets. I still get a little bit of wobble
2016-5-21
ranges
Michael M Posted at 2016-5-21 10:22
Sorry
I was on the A-B not the B-C
2016-5-22
