Northofthe49th
Look at the props on your phantom, two black tips, two gray tips, motors are similarly marked.
Take the faulting motor and exchange it with the opposing known working black or gray motor and see if it spins up properly, if so then it is the ESC board and not the motor...
most as a rule will order the motor and ESC just to be sure and that is how you start your spare parts kit.
FYI...the motors are specific for their location on the phantom, two turn CW, the other two CCW and must be replaced with the correct orientation or your Phantom will have bigger problems.
Phantomhelp.com will have good references for other parts should you need them. |
