Naza M v2 lose control and crashed
1485 3 2016-5-20
zhanyiduo
Specs: S500 quadcopter frame, 3508 700kv motors, 11"prop, board camera, naza m v2 FC. This quadcopter has been flied for 2 years, this is the first crash.
It took off about 3 meters above ground. Then I gave the quad a little pitch, suddenly it lost control and started banking forward crazliy. I tried pull full stick back, but cannot level the quad. Then it started bank right and crashed on my neighbour's roof.
Here is the:
The entire flight was only 20 seconds. From reviewing the osd information, I discovered something abnormal.
The horizon showed level even when the craft was banking hardly. It seems the FC's level input was wrong. I was very confused. Please help me to figure out what might be the possible cause.
2016-5-20
DJI-Jamie
Flight distance : 112405 ft
That does look like a gnarly crash. Could you happen to tell me what kind of iOSD do you use. a Mini or a Mark II? If you have the iOSD Mark II, could you happen to provide the .DAT file perhaps through Dropbox?
2016-5-20
zhanyiduo
DJI-Jamie Posted at 2016-5-20 13:45
That does look like a gnarly crash. Could you happen to tell me what kind of iOSD do you use. a Mini ...
It is iosd mini, no data file. I was feeling like the quad was unable to self-level itself.
2016-5-22
DJI-Jamie
zhanyiduo Posted at 2016-5-23 09:37
Based on the video, I do see that the OSD does show some deviation from level after take off. Just for clarification, when was the last time you performed an IMU calibration? Is the firmware up to date on the Naza V2? Was the home point locked prior to take off?
2016-5-23
