Camera gimble cutting out
966 3 2016-5-20
ed.gregory
Flight distance : 47241 ft
Any help would be hugely appreciated.
Everything seems fine when I start up my inspire 1. No warnings and everything safe to fly. I test the camera on the ground and everything is perfect and working fine. When I take of it is ok for around 1 minute and then the gimble seems to die. The camera just goes limp and unresponsive (facing down. It keeps sending the signal and the rest of the drone is working as normal and expected.
It is windy outside but no worse than I have flown in before.
I have attached a photo as I think I maybe missing a screw. Checked online but can't tell if it should be there or not.
Thank you so much I advance.
2016-5-20
Donnie
Flight distance : 3636782 ft
     The empty screw is normal, it is used for other camera setups.  Now as far as the gimbal going limp, I would make sure all of the wiring is plugged in tight ( fully seated )  I think I would start the aircraft like on a table and closely just watch the camera and gimbal , see if something is makeing unusual  sounds.  The table will bring it close to you rather than getting  on the ground, listen close and make sure the fan is working on the camera and not causing it to overheat if it is not working.
You can also test the camera movement on the decck without the motors on as well, run it through its paces, up down left right and see if it fails.
Also remove the camera from the gimbal and make sure the contacts are clean and making good connection.
Remote diagnostic :   It sounds to me like one of the gimbal servos is failing.
start here and let us know - donnie
2016-5-20
DJI-Ken
Flight distance : 1515312 ft
If you've done all the calibrations and nothing helps and it only does it when in the air then it could be an issue and in need of being looked at and repaired.
If you power it all up and hold the aircraft and move it around (like in flight movements) will it go limp ?
2016-5-20
videoguy
I had a similar problem. Make sure the end connectors on the two gimbal cables are fully seated.  The camera worked but not the gimbal.. Seating the connectors fixed the problem.
2016-5-20
