Battery Charging Hub
1190 11 2016-5-22
keongwee85
Flight distance : 331391 ft
Malaysia
hi
Was wondering is it safe to use this for original battery or i should not risk it ?
any alternative suggestion ?? Thanks,
Regards,
KW
2016-5-22
jbaltimore01
If you do not like that one you can just go on Amazon and there are tons to choose from.
2016-5-22
keongwee85
Malaysia
problem is i am from Malaysia and amazon wont deliver it over ... =( ... so got limited choice ... either go with DJI hub or some 3rd party hub ...
2016-5-22
DJI-Ken
Flight distance : 1515312 ft
I would not use something like that.
2016-5-22
JockC
Flight distance : 459416 ft
I own one of those parallel chargers.  It charges all the batteries at the same time so it does make the DJI transformer get quite hot (the original DJI multiple charger charges one battery at a time so there is no additional load on the transformer). There is no reduction in overall charging time with this parallel charger so you may as well simply charge one battery at a time using the standard DJI charger. Because of the above reasons , I no longer use this parallel charger.
if your objective is to charge multiple batteries faster then I suggest you simply buy another DJI charger.
If you want to simply charge all your batteries without having to manually reconnect each battery one after the other then I would recommend the DJI Phantom 3 Battery Charging Hub which will charge each battery sequentially.
2016-5-22
keongwee85
Malaysia
thanks for the advice ... =)
2016-5-22
keongwee85
Malaysia
Hi guys,
what do you guys think about this charger ? is it safe ?
Regards,
KW
2016-5-22
tritongr
Greece
keongwee85 Posted at 2016-5-23 08:13
Hi guys,
The buyers here appear happy :
http://www.banggood.com/DJI-Phan ... -In-1-p-994587.html
2016-5-22
keongwee85
Malaysia
was thinking to get this or to get the battery hub or another charger ...
2016-5-23
skipilot1
Flight distance : 1557398 ft
keongwee85 Posted at 2016-5-23 13:13
Hi guys,
Love this charger. It is fast. You can charge 3 batteries and the RC in less than two hours. It is heavy (wouldn't pack it for a trip) and has a fan. It runs cool even when all plugs are being used.
2016-5-23
dobmatt
Flight distance : 1831050 ft
I agree with DJI-Ken, this bar has no advantage whatsoever, lots of power is dissipated as heat by these resistors, no gain in charging time, extra stress on charger ... A piece of crap, simply.
2016-5-23
Geebax
The 'charger' supplied by DJI is not in fact a charger, it is simply a power supply, so it is relatively easy to charge a Phantom 3 or 4 battery, just supply it with 17.5 VDC at about 4 amps and it will be happy. As Dobmatt says, that charger bar is a piece of crap, don't touch it. But the blue device is fine, it is just a high current switch mode power supply and will do the job nicely.
2016-5-23
