Not A Speck Of
Flight distance : 666493 ft
I discovered first hand 2 days ago that flying straight up, I had problems sending controls to the craft up at 120m. No matter how I adjusted the RC antennas, it would not budge. I could RTH and it would start to descend, then I could capture control of it. After over a year of using this thing, that's the only time I've had this kind of issue, and that video perfectly explains why.
As for distance problems in general, I didn't have any before the latest firmware updates, and now that I have updated my firmware ... I still have no problems. Like just about everyone else (10s of thousands of people world-wide), firmware did not reduce my distance. The number of people I've seen here blaming the firmware can be counted on less than the total number of fingers I possess.
So if you continue to blame the firmware for your distance problems, then complain until DJI releases a firmware resolution (which will likely never come), then you are not doing anything else to try and fix your distance issues. You know, just in case there is another reason for your distance problems. Just sayin', could be.
