Not A Speck Of
Flight distance : 666493 ft
I think your experience in frying your P2 wifi module tells you why the DJI docs no longer mentions discharging your batteries in the docs. What method did you use? I assume it was something more than just turning it on and letting the battery deplete.
Unofficially, if I remember right, it has been discussed on these boards to condition your batteries every so often by allowing them to deplete until they power off naturally, then fully charge them. There have been no discussions about quick discharging that I recall. Most comments suggested to run the battery down normally by using them in flight; then later at home, turning them on again to allow them to deplete the rest of the way until they just turn off.
I don't remember any discussions about a similar conditioning of the RC battery. In my experience, when I leave the RC powered on with everything else powered down, it will start beeping ~10 minutes later. This is a good thing as I have a few times put the RC away in my backpack after forgetting to power it off. So I don't know if there's a way to power up the RC and let it slowly discharge until it powers down, without the beeping, unless it entails having the AC powered up nearby as well.
Chris
