Phantomski
Flight distance : 14869882 ft
You know guys, since you do not like "other attachments", I would suggest that you guys would at least work out some easily removable landing gear extension... The reason I got mine, is because when initializing the P3 in the grass, or sandy/rocky surface, I see the camera sometimes touch things during initialization... I am sure DJI could do a good job creating something like the one mentioned here. The reason it has to be removable, is because most backpack will not take it. Anyhow, elevating the quad slightly seems like it would work well for many. Not sure if P4 has the same issue, or if u guys made the camera be a bit shorter....
I would certainly say that a raiser for the gear and some kind of protection for the gimbal not to fall off, in case of a rough landing, would be the most common things people would want to add, if they were made by you and "clear for use"....
