Phantomski
Flight distance : 14869882 ft
Not good!
Confirm you did not leave any packaging! There's a small white foamy thing behind the gimbal, that MANY people overlook at first.
Do you have 2nd set of props? Try them.
Also power up your quad on the ground with no props, touch each spinning motor, feel if there ar4e any vibrations.
Confirm that all the screws holding the motors are not to tight, but not lose.
Other than that, yes, initialize on a stable and leveled surface andf make sure the initialization is not interrupted by you touching it or moving it.
Do some testing holding and moving the quad by hand, the motors do not need to be on. Just see if you can replicate it in hand and watch if you can tell if there's something blocking or making weird noise on the gimbal...
