Dropped frames with the raw footage
2747 12 2016-5-25
Sky Lens
Flight distance : 546273 ft
Hello all,
I am experiencing dropped frames when shooting raw (Inspire 1 X5R) on some of my footage.
The DNG sequences clearly show a few missing frames when advancing frame by frame.
I was wondering if anyone had experienced it.
Thanks
Brice
2016-5-25
Chris G
This issue might be related to the Micro SD card you are using. If its too slow to write, you will loose frames.
Check yours compared to this list. https://www.sdcard.org/developers/overview/speed_class/Alternately, I recall seeing a Hardware compression setting, not sure if this exists for the X5r, but try that and see if it helps hurts.
FYI, You probably want a good quality UHS3 SD card, supports 30MB/s
2016-5-27
Sky Lens
Thanks Chris, but it is about the raw DNG sequence from the SSD  not the SD card
2016-5-27
RDTeam43
R&D Team
China
Sky Lens Posted at 2016-5-28 14:39
Did you format the SSD card using the PC/Mac before?
2016-5-28
Sky Lens
RDTeam43 Posted at 2016-5-28 08:00
I don't think so but prior to the flight, I formatted the SSD in the bird.
2016-5-31
gybo102
Flight distance : 2426230 ft
What frame rate are you recording at? And are the drops random or after a certain ammount of frames?
2016-6-1
Sky Lens
gybo102 Posted at 2016-6-1 04:25
Recorded at 29.97 in UHD and no the frame drop is completely random.
2016-6-2
Sky Lens
Here is a low res clip
Password: X5R
2016-6-2
RDTeam43
R&D Team
China
Sky Lens Posted at 2016-6-1 02:53
Please try to format the SSD using the drone again and to see if the problem were solved.
BTW: There was an issue which we have met during the development is an SSD formatted by OSX started to drop frames occasionally, quite similar to your case.
2016-6-10
Sky Lens
RDTeam43 Posted at 2016-6-11 10:28
BTW: Th ...
Thank you for the response.
I'll let you know.
2016-6-14
Sky Lens
After reformatting the SSD and reloading the latest firmware it seems to be working in 4K. I still have to try it in UHD which the faulty footage was shot in.
Difficult week for me. One of my  new GoPro Hero4 Black is a lemon. Going back today for an exchange.
2016-6-16
Sky Lens
All is good, shot some UHD footage yesterday and it looks great. No dropped frame
2016-6-17
Dronie.dk
Flight distance : 8077667 ft
Denmark
RDTeam43 Posted at 2016-5-28 17:00
You can't format SSD on pc/mac - only via the app.
DJI didn't have time to fix CineLight as they where probably busy creating Chinese New Years themes for the mickey mouse editor in the GO app.
2016-6-20
