Buzzer Beep sound in Gimbal after changing ribbon cable
1337 1 2016-5-27
saravanavideos
India
My Dji Phantom 2 vision plus had ribbon damage due to mishandling of the camera.i have replaced with new ribbon cable and now i am hearing Beep sound (Beep Beep Beep) in Gimbal. Gimbal no movement and no video in the monitor
Please instruct what to do
Advance thanks for your reply
2016-5-27
Northofthe49th
What color/light sequence is coming from the camera LED?
i would remove and re install, not sure if you have seen a youtube video but likely something did not go back together correct if it was not making the noise before.
Any chance the cable you got was damaged?
The camera does not beep, it is an error coming from the camera, at least i am pretty sure as i have never heard of a beeping camera and the error indicators do not indicate any noise emission,
There are several connectors at the base of the gimbal, make sure all are in correctly and seated firmly,
Also may be something internal on the Phantom disconnected
2016-5-28
