Donnie
Flight distance : 3636782 ft
Be sure to enable the "Hardware Decode " On the Dji Go app and also clear the Video Cach as well. Maybe the Device the go app is on is having trouble keeping up with the sudden movement. By enableing the Hardware decode , you will take some of the strain off the processor and by clearing the Cache it will also take strain off the processor.
Of course always check all your connections between the camera and Gimabal .
I am not sure if the new update caused this or if some of the settings were changed when you updated the RC.
Also on the camera setiing on the go app ( Far right on main screen ) be sure to open and make sure you Re- set them and then make sure they are all to the USA standards and not european Like the "PAL and "NTSC (?) " also the Hrz rating is set to 60 anti flicker enabled ETC. I am not home right now to look at my Go app but you get the idea to check the settings .
Are you getting any pixealtion while recording to SD card or only when it is live transmission ? This willl tell you whre the problem is located, on the camera itself or on the Image transmission. If the Video Transmission then check and make sure the Channel is set to Auto and not locked on custom, always after updates go through every screen and make sure the settings are where you like them, what I do with my I pad is take screen shots so i can remember what my sweet spots are.
This should get you pointed in the right direction, and any of my peers may have other ideas as well....
Try these first and see if it helps - donnie
