Follow me mode...weak GPS -not enough satellites..
1514 6 2016-5-28
dentin11
Flight distance : 155646 ft
Every time I try using Follow me mode, I get an error message not enough satellites.  BUT I have 16 satellites engaged!    Waypoint works fine, Bird flys great!
Anyone care to comment?
2016-5-28
Stephen Marley
Had my Inspire pro since January and still haven't had follow me work. Always the same message even when I have 20 satellites.
2016-5-28
Cougar1
Flight distance : 924393 ft
Don't think the weak signal is from the Inspire, as you say you have many satellites. Think the message is about the RC, make sure the front of the controller sees the sky. You can also use a device/tablet that have a GPS built in like a cellular version of iPad.
Sattelite count in the app is for the aircraft position, the Inspire controller has it's own GPS in the front and that is what is used for "Follow mode". the gps must see the sky but is somewhat limited and you are better off with an ipad with built in GPS.
2016-5-28
dentin11
Yes. Good point. I will try later with iPhone 6 Plus S!  That's probably the reason. A few weeks ago it worked fine on my other inspire but I think I was using the iPhone
My mini is wifi only
2016-5-28
dentin11
2016-5-28
dentin11
Hey Stephen, were you using a wifi only device?
2016-5-28
Stephen Marley
dentin11 Posted at 2016-5-29 07:34
Was using iPad air 2 wifi only, will try using the iphone 6 see if that works.
2016-6-3
