RichJ53
Flight distance : 1837356 ft
see this step by step from project41
Firstly i was upgrading from 1.5.00.30 and there are a few things to note.
The firmware upgrade on the aircraft is done from the micro SD card.
The firmware upgrade for the transmitter is done via The Go App and NOT the micro SD card.
This is important, also ignore what the Go App says when you turn it on, if i had updated the transmitter following the Go app i would have been in a world of pain.
These are the steps i took.
Preperation
1. Download the firmware update from the DJI Website, extract the zip file to get the .BIN file.
2. format the micro SD card in the inspire 1 (i did it via the go app as i know this works)
3. Copy the firmware .BIN file onto the micro SD card and put it onto the root of the card.
4. Take the inspire 1 out of transport mode and fit the camera gimbal
5. Make sure your transmitter(s) and flight batteries are at least 75% chaged to be on the safe side.
6. Make sure your DJI GO App is up to date, the current version is 2.8.1
6.. TURN OFF EVERYTHING.... AIRCRAFT, TRANSMITTER and GO APP, this is the best place to start to make sure nothing goes wrong.
Inspire 1 firmware upgrade
1. Insert the micro SD card into the slot in the camera
2. Make sure your transmitter is turned off.
3. Power up the Inspire 1
This will now go through its start up proceedure, it will sart to bleep with 4 short tones and then a pause so dddd - dddd - dddd -dddd and so on. This is letting you know thet the firmware upgrade has started.
IMportant..... be patient it takes time, in my case it took around 15 mins to do the firmware upgrade, do not be tempted to power it off, the light at the back of the inspire will flash in various colours and patterns
but ignore it.
Wait for the tone out of the inspire to change to one long beep and two short so d-dd d-dd d-dd and so on, this is letting you know that the Inspire 1 firmware upgrade is completed.
4. power down the Inspire 1 and take out the micro SD cardand put it into your computer, on this card you will find a .txt file, open this and confirm that the firmware upgrade has been sucessful.
5. do not remove the firmware .BIN file off the micro SD card, you will need this latter to upgrade the firmware in the batteries. Better to do it now than in the field.
6. Reinsert the micro SD card in the Inspire 1 but do not power it up at the moment.
Thats the Inspire 1 upgraded.
Transmitter upgrade.
This is done from the DJI Go app.
1.turn on the transmitter and connect it to the ipad.
2. Run up the Go App and connect it to camera view.
3. Press the status bar next to the DJI logo in the top left, it will say aircraft disconnected.
4. You will see a red triangle with transmitter firmware needs updating. This is done via the internet so make sure you have a good wifi connection to the internet to do this.
5. Follow the prompts to do the firmware update, again be patient, you will know when it has updated the firmware on the transmitter as it will tell you and you will see a green tick on the screen.
6. Power down the transmitter, asnd back up again, power up the Inspire 1 and then the Go APP.
7. In the Go App press the general settings button (top right of the screen 3 dots.
8. Go to the bottom of this screen and press about., this should now show you that the aircraft and camera is on version 1.8.01.00 and the transmitter is on 1.6.0, this is the case on my setup.
Batteries
Yep these need doing as well but you have already done one on the initial firmware upgrade of the Inspire 1.
Any additional batteries will need to be upgraded but this is straight forward if you have followed the above proceedure.
As you still have the firmware .BIN file on the micro SD card that is in the camera gimbal you have the files you need to do this, now you see why it was left on there.
1. Unplug the battery in the Inspire 1 that you used to do the firmware upgrade.
2. plug in a battery that needs to be upgraded (at least 50% power)
3. Turn on the Inspire 1
4. The inspire 1 will go into the firmware upgrade process again but this time it will only update the battery firmware as that is detected. This is a lot faster than before and only took me a few minutes but best to do it in a workshop and not the field.
5. Follow the bleep tones as before for the Inspire 1 firmware update, again be patient, its so worth it in the long run.
6. Once the firmware update has been done power down the Inspire 1 and repeat for all of you batteries.
Ok thats the firmware upgrade done in the Inspire 1, camera, batteries and transmitter but you are not quite done yet. The final step is important.
REMEMBER
RECALIBRATE THE IMU, GIMBAL AND TRANSMITTER before flying, this is good practice after every firmware update.
On your first flight after a Firmware update make sure that all functions and controls work as expected and that includes landing gear and return to home
by project41
Rich
