terrylewis
Flight distance : 3517287 ft
Our DJI Aircraft use micro SD Cards up to 64GB in capacity. For cards less than 32GB, the aircraft formats them as FAT32 because of the max volume size limitation of FAT32.
For FAT32, the maximum file size is 4GB.
For 32GB and 64GB micro SD Cards, the system formats these card as FAT64 (exFAT) because it is more efficient and has much greater file and volume limitations -> 128PB max volume and nearly unlimited file size.
However, the software that wrties the file to the SD Card uses the least common denominator and always truncates writes less than 4GB regardless of FAT32 or FAT64 (exFAT)...
So as stated previously, plan your shots accordingly.
