New Firmware for Phantom 4 v1.1.410
29691 281 2016-5-31
MikeFrey
Flight distance : 4661821 ft
ppeepp5 Posted at 2016-6-1 00:49
Hello, it's impossible to update using DJI Assistant on MacOS....
I had the same trouble updating with my Mac. I found Colin Smith's tutorial for updating to be more useful.
2016-5-31
anders_alergard
Flight distance : 708264 ft
Sweden
M Stuart K Posted at 2016-5-31 22:39
What are you referring to as a pack?
Since English is not my native language there might be other people more suited to answer that then me. But quite certain it's battery pack they are referring to.
2016-5-31
mjanzou
Flight distance : 14820 ft
Used a win-7 pc with asistant-2, hung at 92% which is where it did a reboot but never came back....
restarted P4 and assistant-2, came up as 100% complete v410
Hmm last time it got to 99% and hung the same.....v301
Ive never gotten to 100% on the assist2 app yet both times upgrade was completed...........wtf?
2016-5-31
v.razaitis
Lithuania
Started the Upgrade it went up to 66%, then suddenly aircraft automatically disconnected from my pc and upgrade was interrupted.
Tried to restart the upgrade it fails at 0%, tried formatting SD card, tried to downgrade - it fails at 0%...
No idea what to do, in DJIgo app Aircraft firmware - N/A.
GG...
Any suggestions?
2016-5-31
jp.falguieres
Flight distance : 1765486 ft
Voic i le résultat de cette nouvelle version :
2016-5-31
CitizenKane
I'm confused.  Maybe someone can explain what I'm missing here.  My iOS devices were updated with Go on 5/25 to version 2.8.2 and that's when I got vid transmission problem.  Worked great before and poorly afterwards with banding, black-screens, etc. after the update.  Above it says 2.8.2 (same version) is released today 5/31.  How are they releasing the same version?  PS.  I don't see that new update mentioned in this thread on my iOS devices yet.
2016-5-31
hallmark007
Flight distance : 9827923 ft
sploodge Posted at 2016-5-31 17:25
Firmware works fine, flown 6 packs on it..
Remember there is also a battery update so if you save m ...
Sorry maybe you can help me where did you see there was a battery update
2016-5-31
J.N
Flight distance : 102333 ft
ferdejuancuenca Posted at 2016-5-31 22:57
i will have my new Ph4 tomorrow. do i have to update?
Any advice for a new user?
Read the manual watch as many  tutorial videos videos as you can. Start with small flights, Know the bird and enjoy. buenos vuelos
2016-5-31
Domenico Panace
Flight distance : 34751 ft
thanostc Posted at 2016-5-31 15:41
What is changed in gimbal initialization tone?
Gimbal initialization tone has not changed in my Phantom 4!
2016-5-31
ferdejuancuenca
J.N Posted at 2016-6-1 01:11
Read the manual watch as many  tutorial videos videos as you can. Start with small flights, Know t ...
thanks! i hope not to have many problems with the app, and things like that
2016-5-31
Old Geezer
Flight distance : 23691 ft
calls4u2 Posted at 2016-5-31 17:32
25mph+ up here in the North East - I'll not be testing mine today for sure!
Only 25+ ?
Up here on the hill tops of Northumberland we had to use four people to hold the roofer's ladder in place while he fitted a new vent tile for the bathroom extractor ... my Phantom sat on the windowsill indoors laughing at us through the window.
2016-5-31
stephen_carney
Flight distance : 70873 ft
My Samsung Tab 2, was notified of a firmware update, downloaded it, plugged it to my phantom 4, and updated firmware,
It finished, all good, as easy as that, have noticed that some of the menu's changed, went through them all and reset to my settings.
2016-5-31
grangerfx
Flight distance : 817713 ft
I just did a couple of longer range flights (8-9 thousand feet) with the new firmware and the 1.8.2 app. I think that the firmware worked fine but the video drop outs were a much bigger problem. I can see that the bit rate has a lot to do with the problem. Lowering it to the minimum got me extra range. I also set the channel to 13 which is supposed to work the best. This was over a rural type community so not much WiFi interference. By the time the drone was to 8000 feet, the video barely worked at all. The signal strength still showed it being strong so the problem is that the bit rate is not getting adjusted automatically for the signal strength/range.
2016-5-31
Aardvark
Flight distance : 384432 ft
v.razaitis Posted at 2016-5-31 23:02
Started the Upgrade it went up to 66%, then suddenly aircraft automatically disconnected from my pc  ...
Just let it run these aircraft resets are part of the update process.
2016-5-31
aerialphotograp
Thailand
Mine still has the altitude problem
2016-5-31
grangerfx
One more thought: It sure would be nice if all the settings did not get reset every time I do a firmware upgrade. Hey DJI, how about saving them as an XML file so you can reload them safely and automatically after the update?
2016-5-31
ISA AYDIN
Flight distance : 504692 ft
This release is just another proof that DJI will continue ignoring us and the problem with horizon, altitude dropping and the weak signal issue will not be solved. Everybody is screaming around and they just don't care. All they care is selling out RAW drones and collecting money. I personally quit. Selling mine ASAP.
2016-5-31
net_box
I admit it: I am still scared to do a firmware update!
Some say use the app, some say use the DJI pc program.  What works better?
I just downgraded my app to 2.8.1  so maybe I should use the WIN program?
And then what do I do to update the silly batteries?  Do I start the firmware
again for each silly battery?
Can we have an official step by step manual how to do the firmware updates?
Even though the next question doe snot apply in this update:
Are we supposed to do the craft first and then the controller?
On the P3 when I did a few craft first, then the controllers would no
longer connect....  I am Confused and Afraid
2016-5-31
rodger
Flight distance : 20145135 ft
2,3,&4look great Tim. Thanks for the heads up.
2016-5-31
Advocate
Flight distance : 1076909 ft
Sorry to hijack the thread like this guys but I just wanted to say.......Yippee I'm not the only one here from the NE of England! There's at least two more of you
2016-5-31
thanostc
Greece
Domenico Panace Posted at 2016-6-1 02:18
Mine went away!! If we mean the same sound...
2016-5-31
calls4u2
Flight distance : 211604 ft
Maybe it's me, but since the update I can't find where I set the still image resolution?
2016-5-31
johnchao411
Flight distance : 45364 ft
Taiwan
ville.honkonen@ Posted at 2016-6-1 03:06
I start the P4 inside after the update, and the warming up time is normally 2-4min, now it takes abo ...
is that something good?
2016-5-31
johnchao411
Taiwan
mikedruben Posted at 2016-6-1 00:31
I'm on  v1.1.410 and 2.8.1 upgrade went good, one little issue I started out in p-mode then went to  ...
Thanks for your sharing, hope this little "glitch" isn't bringing up any serious issues...
2016-5-31
vandruten
Indonesia
Wowzers... over 2000 views and over a hundred replies in less than 24 hours!! What a thread!!!
Watching while having nice warm cuppa
2016-5-31
sploodge
Flight distance : 809350 ft
M Stuart K Posted at 2016-5-31 21:39
battery packs
2016-5-31
sploodge
hallmark007 Posted at 2016-5-31 23:35
You will see the battery lights change to have the second and third light flash during firmware update, its at this point it is updating it. If you have more than one battery, put the other one in and the GoApp will say the firmware is inconsistent and allow you to update the other battery(s).
Have a look here for info ( near the bottom of the post )
http://www.phantom4-guide.co.uk/ ... -v1-1-410-released/
2016-5-31
pentagon78
Flight distance : 520233 ft
Malaysia
sploodge Posted at 2016-6-1 15:53
You will see the battery lights change to have the second and third light flash during firmware up ...
Hi Sploodge, my phantom is still running with old which is v1.0.288. My controller is also with old firmware. I have no confidence in new firmware. Heard you have updated to latest firmware V1.1.410. Does it fly well? any issue so far? should I go for the update?
2016-6-1
sploodge
pentagon78 Posted at 2016-6-1 09:01
Hi Sploodge, my phantom is still running with old which is v1.0.288. My controller is also with ol ...
No issue I have noticed. The only issues I have seen other have is when installing it ( not any issue with it flying )..
The worry with remaining on an old firmware is that maybe DJI resolve an important issue that was never documented in the release notes or that many users would have encountered..
Installing or not is your choice
2016-6-1
pentagon78
Malaysia
sploodge Posted at 2016-6-1 16:27
No issue I have noticed. The only issues I have seen other have is when installing it ( not any is ...
Thanks for your information.
2016-6-1
chaykyme
Thailand
My first update via DJI Assistant 2 got stuck at 36%, turned P4 off and tried again and 100% complete 2nd time with confirmation message, now I noticed updates to Android and Apple apps, both updated, will test now with Android tablet
2016-6-1
hallmark007
sploodge Posted at 2016-6-1 08:53
Thanks Sploodge got it
2016-6-1
mavs88
Flight distance : 8953215 ft
There are TWO things: Firmware and the DJI GO App... allthough working together the problems came from both sources. But there is a NEW firmware AND a new version of the DJI GO app............. going for a test soon....
2016-6-1
pentagon78
Malaysia
mavs88@home.nl Posted at 2016-6-1 17:20
There are TWO things: Firmware and the DJI GO App... allthough working together the problems came fr ...
They said don't update DJI GO apps to 2.8.2
2016-6-1
cayalag
Flight distance : 470656 ft
Portugal
stuck at 99% after upgrading from the DJI GO APP... once you start the transmitter, it completes to 100 %
Also the annoying gimbal sound on start-up is gone ;)
2016-6-1
pentagon78
Malaysia
IOS DJI GO 2.8.3 has just been released!
2016-6-1
RemusE
Flight distance : 1145869 ft
Sweden
updated aircraft v1.1.410 and android 2.8.1, had 3 flights, no problem.
2016-6-1
cayalag
Portugal
I flew a couple of batteries with the new update:
- With the previous version v1.1.301 I NEVER HAD the altitude drop when stopping... after the upgrade, with the new version, I am sadly experiencing it... but on the funny side, sometimes it goes up as well, instead of down (1 out of 10, lets say)
- I am still running DJI GO app v2.8.1, and also after the upgrade I had a couple or artifacts and green bands in the screen when I was waiting for the IMU initialization... something that never happened with the 1.1.301 either.
DJI, is it worth it for me to upload the log anywhere ?
2016-6-1
jruizo
Flight distance : 546545 ft
Just Updated my Phantom 4 which I received las week of April.
Yesterday night (Time in Spain) I upgraded first DJI GO App both in my iPhone and iPad mini. In the case of P4 firmware, I used DJI Assistant in a portable Asus PC running Windows 8. DJI Assistant did not alerted me to upgrade it.
First time intent to upgrade the firmware failed. I got stuck not knowing what to do, until I realized that the battery in the drone was at only 20% juice. After charging it, everything went smoothly. When the "Success" notice appeared in the screen, I switched off the drone... and it re-started WITHOUT the squeaky annoying noise in the camera gimbal ! Transmission weak signal alert has also dissapeared    :-) Ihave noticed also that some personalized settings like advanced flight modes "on" and other  photo and video settings have reset to initial default. Please, after upgrading I recommend to check all settings just in case some of them went lost.
I have four batteries, and when plugging the ones not used during the upgrade, DJI Assistant showed the need to upgrade the Phantom firmware as if this had not been made yet. No other sign of my previous succesful operations appearde as well. Thus, I have had to upgrade four times, but the second, third and fouth tiem, the process was much much shorter: around four to five minutes. The last battery update lasted only 55 seconds.
I will fly next saturday, and will post any relevant result.
2016-6-1
vincentnursalim
Flight distance : 2106204 ft
Indonesia
Anyone , did the new Firmware fix the tilt gimbal issue ?
2016-6-1
