What is the best solution for balancing the 4th axis at the Ronin?
693 3 2016-5-31
stompdance
Ukraine
Hello! Whta is the bet solution for balancing the 4th axis at the Ronin?
2016-5-31
valealvarez.s96
Argentina
4th axis? Which one? Specify more, the pan axis, the tilt axis + the dovetail, or the roll axis
2016-5-31
stompdance
Ukraine
Flowcine Serene for Easyrig or set Ronin on the arm from Stedicam
2016-5-31
valealvarez.s96
Argentina
stompdance@ukr. Posted at 2016-5-31 16:42
Flowcine Serene for Easyrig or install Ronin on the arm from Stedicam
The best solution to solve vertical movement is the Flowcine serene + 2 axis puppeteer + easyrig.
The steadycam arm can work too, but the first one works best
2016-5-31
