Phantomski
Flight distance : 14869882 ft
Definitely a cable issue, but could be the scratch on the cable causing a short when vibrating, oir the impact could have caused some cable inside to become lose. Perhaps there's an electronic part inside that's lose - but certainly looking into the cable would be the easiest.. i wonder if you could use some glew to cover the scratch, so even when it vibrates the wires cannot contact each other.
That would be what I'd try first.. What if you turn it on and check what happens as you move, rotate the aircraft? anyways, some ideas here, hope you gonna get more good suggestions from others.
