Donnie
Flight distance : 3636782 ft
When placing in travel mode make sure Camera is removed, this may be your problem
OR
The VPS sensor is having trouble sensing the ground, that is what it will do when it cannot sense the surface below it. Have him change the VPS sensor or make sure the one installed is clean and plugged in properly. Ideally the surface to use is a Hard shiny reflective surface, I use my hardwood floors in my home with a glosses finish, some pilots use the case of the Inspire.
The gear should not be raising when the aircraft is on the ground, this would damage the camera.
Either you have the camera attached and the Travle mode wont work ( Normal ) or the VPS is damaged
Notice in the picture below, there is no camera attached when entering or disengaging travel mode.
Are you switching the landing gear slider control up and down 4 times with the camera removed and on a hard level surface ?
Have you tried to enter travel mode using the Go App ? It is located on the very bottom of the "system staus" Page
good Luck
Let me know the outcome please
donnie
