david.p.mann
Flight distance : 18669501 ft
I believe it is a way for the P4 flight logic board to check for the presence of properly attached props on all four motors by looking for resistance to increased motor speed. If you arm your P4 with no props attached, for example, you will typically get a warning message while the P4 is on the ground with motors running. I can't remember the exact message - something about rotors. This testing is a good thing. For example, if one or more props were not securely mounted (due to incomplete or improper quick mount procedure), then a prop could fly off shortly after takeoff resulting in a crash. |
