How to connect my p4 controller to my pc and play a sim. with it ?
9110 20 2016-6-3
860462
Hello there, im happly to announce that i got my p4 yesterday. I live in uk/lndn and as you can guess wheather is not suitable most of time and its forbidden with drones in many places here. I know its not like real experience but i still want to try some drone simulators by using my p4's controller. Do u know how to my recognize it to my computer somehow as an input device ? (not want to play the one comes with ios app.)
Thank you and hello to everyone again.
2016-6-3
860462
Well, many people read it but no one replied it..
Can anyone say how to understand when battery of the phantom have fully charged ? All lights of battery's are flashing like from little to big one. Should i stop it at one point ? Or it can stop own its own ? And same question for the controller ?
Thank you.
2016-6-4
lpfreeking976
Flight distance : 131224 ft
I have no information on using simulators other than DJI GO APP.  For battery charging all  lights flashing is nearly full, ( there is a chart in the manual).   When the charge is complete the battery will turn off & all lights will be out.
2016-6-4
DJI-Ken
Flight distance : 1515312 ft
860462 Posted at 2016-6-5 08:32
Can anyone say how to understand when battery of  ...
When the battery is fully charged all the lights will go out.
Remember, if the battery is nearly full, you have to power it on first then connect it to the charger otherwise it will not top off the charge.
2016-6-4
calls4u2
Flight distance : 211604 ft
Don't worry about flying dude, head out of town and find a big flat area. Read the manual, watch the tutorials.. and have fun. Easier than you think!
2016-6-4
860462
DJI-Ken Posted at 2016-6-5 02:19
Remember, if the battery is nearly f ...
Thank you for reminding it should I turn on it every time before I plug to charger ?
2016-6-7
860462
calls4u2 Posted at 2016-6-5 08:28
Don't worry about flying dude, head out of town and find a big flat area. Read the manual, watch the ...
Haha yes it was !! Actually it was easier than simulators !!!
2016-6-7
860462
DJI-Ken Posted at 2016-6-5 02:18
I have sent a message regarding the P4 simulator, I also cannot arm the motors.
So is there a way for using our controller as a joystick for computer ?
2016-6-7
DJI-Ken
860462 Posted at 2016-6-7 23:22
yes, in simulator mode and aircraft powered up and connected to your computer, the RC has all the functions as regular flight.And the simulator is working fine now.
2016-6-7
PhanFran
Flight distance : 4804163 ft
Belgium
860462 Posted at 2016-6-7 17:18
Please, please, please just READ the manual at least TWICE from the first page to the last otherwise your shiny P4 will soon be a piece of garbage. All the answers to your questions and much more are in the manual.
Don't understand why you would want to use the RC connected to your PC but there is a simulator included in the RC-app. Try that one !
2016-6-7
Airspace Explor
DJI-Ken Posted at 2016-6-7 08:40
yes, in simulator mode and aircraft powered up and connected to your computer, the RC has all the f ...
What is connected to your computer, the AC or the RC?
2016-6-7
DJI-Ken
Airspace Explor Posted at 2016-6-8 03:17
The Phantom
2016-6-7
Airspace Explor
OK. Do you mean via the USB cable? So what program is running on the computer?
2016-6-7
DJI-Ken
Airspace Explor Posted at 2016-6-8 03:22
Yes, for the P4 you connect the aircraft to your computer via USB cable and run the DJI Assistant2 software.
2016-6-7
Airspace Explor
DJI-Ken Posted at 2016-6-7 12:43
Yes, for the P4 you connect the aircraft to your computer via USB cable and run the DJI Assistant2 ...
Is this program available for the Phantom 3 4K? I don't see it listed in the downloads section http://www.dji.com/product/phantom3-4k/info#downloads .
2016-6-7
DJI-Ken
Airspace Explor Posted at 2016-6-8 04:10
Is this program available for the Phantom 3 4K? I don't see it listed in the downloads section htt ...
No, the simulator for the P3 is in the Academy section of the app. from the homepage, it's the graduation hat icon upper right.
2016-6-7
860462
So, i should i connect my phantom to the pc for using my dji controller ? Cant i directly connect the controller via usb ?
Im planning to use realflight and aerofly simulators which is installed my computer ?
2016-6-7
DJI-Ken
860462 Posted at 2016-6-8 05:41
So, i should i connect my phantom to the pc for using my dji controller ? Cant i directly connect th ...
The Assistant simulator is for the P4 only and uses the P4 RC.
If using a different flight simulator I have no idea if the DJI RC will work.
Try it and if it doesn't, then you have your answer.
2016-6-7
860462
DJI-Ken Posted at 2016-6-7 22:46
If using a different flight simulat ...
I couldnt make it. Nothing happens when i connect the controller to computer. Should i connect it with big usb socket or the little one ?
2016-6-7
DJI-Ken
860462 Posted at 2016-6-8 05:57
I couldnt make it. Nothing happens when i connect the controller to computer. Should i connect it  ...
Then it doesn't work. And that's it.
2016-6-7
860462
thats sad.
2016-6-7
