Not A Speck Of
Flight distance : 666493 ft
Just to make sure (you said most of this above, but just to be sure we're on the same page):
- You have Intelligent Flight Mode turned on for the craft in the GO App. (Note: if you have more than one craft, it needs to be set for both--the GO app saves settings per craft.)
- And you have, during flight and in the air, the switch in F mode on the remote control.
- You are aware that the location of the Intelligent Flight Mode modes in the Go app have changed in different versions. In the current version, when you switch to F mode on the remote, a new icon appears on the left hand of the screen, the bottom most of about 3 icons.
If all of that is true, does the GO app give you any kind of message or change at all when you switch to F mode on the remote?
As for opening it up, if it's in warranty, I would not.
Chris
Edit: changed OIC to "Intelligent Flight Mode" since it no longer seems to be called OCI.
