Phantomski
Flight distance : 14869882 ft
How far were you from takeoff point when that happened? Smart Return home will attempt to calculate if you got enough power to return home... I am on Phantom 3, not sure what model you got, but i would assume the same functionality. You can disable "Smart Return Home" in the app.. it still leaves the standard RTH alone, but will not do all the other "extra stuff"... See if you think that could be the issue.. If not, then I am not sure at this stage. |
