Lightbridge 2 not powering up
1079 1 2016-6-7
Sephiroth8912
Uruguay
Greetings,
I have set up an S1000 and connected everything according to the manuals and tutorials from DJI. The problem is that the LB2 is not even powering up, re-checked all wiring and seems fine. The wierdest part is that even when I connect to the USB port for firware upgrade I am getting NOTHING, no lights, no response, nothing at all... I suspect there might be an issue with this device?? Could it be broken from factory already? Any suggestions??
Thank you
2016-6-7
Haga
Austria
he LB2 Air module receives the power from the gimbal, you have not installed Gimbal?
2016-7-20
