The Steps :
1. Download the firmware at http://phantomhelp.com/Mobile/Phantom-3-Standard/#FirmwareArchive and select the fw that you want .bin file format
2. Insert the file to sd card, outside folder, and must be the only one .bin file format 3. Turn on the RC and the drone without sd card until it connect (RC and Drone) 4. Connect to DJI GO App (to see downgrade status stay at front page of the app) 5. Insert the sd card. Then the downgrade process is starting and rear led will turn to yellow and there will be beep sound from the drone (it is normal). See at DJI GO app, there will be status bar show the downgrade process. If the rear led becomes green it means the process is complete, you also can see the succes notice at DJI GO App. 6. Restart the RC and Drone, connect DJI GO App, check the FW. Finish. I hope it can help the issue of 1.6.80 firmware for Phantom 3 Standard NOTE : DO IT WITH YOUR OWN RISK! Credits go to reinzneal. I just reposted to get it noticed.Just saw the guide was posted before. Click here for the original thread. |
