endotherm
Flight distance : 503241 ft
When you do a firmware update to the aircraft, the battery may also need to be updated. If the firmware is intended to update the battery as well (not all firmwares are) it needs to be in the aircraft and turned on. It will upgrade the battery while it is doing the main upgrade to the aircraft. If you have multiple batteries you need to repeat the process with each of them. As you only have one battery at the moment, it's not really an issue as the aircraft would have been powered on with it at the last upgrade. I think ryanbattey was referring to a possible mismatch of firmwares in the aircraft and in the battery, which could occur if the battery was sourced after the aircraft was last updated or came from a different aircraft etc. |
