DJI-Jamie
Flight distance : 112405 ft
You won't need to apply firmware everytime you switch between cameras, but you want to keep both up to date. Whenever you perform updates for the unit/cameras, here's what you would do:
When updating the Inspire w/ Raw, you'll use the Inspire 1 RAW firmware.
When updating the Inspire w/ X3, you'll use the Inspire 1/V2 firmware.
If you update the Raw prior to the X3, it will not reapply any firmware to the aircraft itself (the craft uses the same firmware) the firmware would only be applied to the X3
