AtomicKid
Flight distance : 366270 ft
I've been performing some test recordings today with the OSMO, using the Zenmuse X3 from our Inspire 1. To get a few things out of the way:
Runing the latest version of the DJI GO app on my iPhone 6, running the latest iOS version.
Upon initial launch of the app for the first time I was prompted to download and install the latest firmware onto the OSMO, this has been done.
Memory card has been formated via the DJI GO app and has worked fine in our Inspire 1.
Battery fully charged.
The problem: I am getting very inconsistent recording lengths, and while recording, if I move the OSMO around much at all I lose the WiFi connection between the Phone and the OSMO. First I lose the video signal, though it still says it's recording (timer advances). Then, the HUD resets to the "N/A" on all fields. At this point I stop the recording.
I've pulled the clips off the card and the video signal immediately stops coinciding with that original loss of picture. Most of the recordings are in the :05-:30 range. The longest one, about 1:00 was only acheived by keeping the unit very steady and not panning the camera.
Tried some of the "fixes" indicated on the forums. Adjusting the video size (latest test was 1080p60 NTSC). Everything else is set to AUTO. This has had no effect.
I also tried switching between the 2.4 and 5G connections. No noticible improvement. Side note, this process never goes smoothly. After changing the wifi channel, it takes multiple attempts to get it reconnected via the WiFi.
So at this point I'm not sure what to try next.
