buy phantom 3 Pro and comes with firm 1.5.30+
1321 7 2016-6-10
javgutierrez14
my phantom 3 Pro comes with firm 1.5.30+
DJI you recommend upgrading to the latest version but only read bad reviews.
which means that "+" in the firm?
I read the 1.5.30 has battery management problems.
what dou you recommend??
sorry I use google translator.
firm
firm
firm
firm
2016-6-10
DroneX4
Flight distance : 180584 ft
From what I can gather 1.5.30+ is actually 1.6.40 firmware. I have the same on my P3
2016-6-10
Aardvark
Flight distance : 384432 ft
The '+' indicates that some modules need updating but not all.
2016-6-10
DJI-Paladin
Flight distance : 2408 ft
Hello javgutierrez14, the ‘+’ doesn‘t matter. What Aardvark says is right and it is recommended to keep the firmware to the latest.
2016-6-11
javgutierrez14
Thank to all, yesterday upgrade to the latest version, and tomorrow maiden flight
2016-6-12
DroneX4
DJI-Paladin Posted at 2016-6-12 12:12
Hello javgutierrez14, the ‘+’ doesn‘t matter. What Aardvark says is right and it is recommended t ...
This is misleading, and incorrect. The "+" does matter. Please see THIS POST by DJI-Ken:
http://forum.dji.com/forum.php?m ... &fromuid=300637
I have also confirmed for a fact my P3A (which says 1.5.030+) actually has 1.6.040  firmware.
Just updating this post with the correct information for future visitors wondering about the "+" sign in their firmware.
2016-6-21
DJI-Paladin
DroneX4 Posted at 2016-6-22 13:12
http://f ...
The "+" in the end of the number of the firmware version doesn't influence the normal operation of your aircraft. Besides, it is recommended to keep the firmware up to date.
2016-6-21
DroneX4
DJI-Paladin Posted at 2016-6-22 14:11
The "+" in the end of the number of the firmware version doesn't influence the normal operation of ...
The "+" sign has relevance and that can indeed influence the operation of the aircraft. For instance, 1.5.030 has a known battery issue that can cause the aircraft to fall from the sky, whereas 1.5.030+ (i,e, 1.6.040) does not have that issue because it has been fixed. I understand what is recommended by DJI regarding keeping firmware up to date, just want to be factually correct about the firmware versions and what the "+" sign means rather than say it is of no significance.
2016-6-22
