CONTROLLER DON'T CHARGE
1299 16 2016-6-10
michele-anna201
Hi, i have bought a Phantom 3 4k by Eglobal , it arrived to me, but when i try to switch on the controller, it doesn't go. I have put it in charge with its charger, and the first white led flashing for one hour while charging, but after it go off....!  I tried to switch on and it go on, but it is in alarm, with the red and the first white led flashing, ad alarm bip-bip-bip.... ! I attach video, and i hope somebody can halp me please.. :-(  Thank you so much for answer...
2016-6-10
one_square_nut
michele-anna201,   This might sound really stupid but try plugging your controller's charger into a different outlet.  Or try a different charger.  Power receptacles do go bad and you may not know it. Let it charge overnight.  If it still doesn't charge, contact DJI for further assistance.  :-)
Steve
2016-6-10
Anacapri
one_square_nut Posted at 2016-6-11 05:56
michele-anna201,   This might sound really stupid but try plugging your controller's charger into a  ...
Hello Steve ,
I tried it in different outlets but the problem remains .
last night after two hours of charging is off by itself but has not charged the battery .
2016-6-10
DJI-Paladin
Flight distance : 2408 ft
Anacapri Posted at 2016-6-11 14:49
Hello Steve ,
last night after two hour ...
Do you make the connectors tightly?Does the power level go up after charging for hours? charging connectors.jpg
2016-6-11
huntcool001
Try plug and unplug and see if the connection is firm. If you still doesn't work, you have to contact DJI Europe and they'll give you a new one.
2016-6-12
Anacapri
DJI-Paladin Posted at 2016-6-12 06:18
I loaded for two hours after power itself down but not loaded
2016-6-12
DJI-Paladin
Anacapri Posted at 2016-6-12 18:12
It is probably a hardware issue. I'd suggest you to get in touch with our EU support and send the RC for diagnosis. 联系欧洲.JPG
2016-6-12
Anacapri
Anacapri Posted at 2016-6-12 12:12
in this way the LEDs flash when I connect the charger
2016-6-12
DJI-Paladin
Anacapri Posted at 2016-6-12 18:36
https://www.youtube.com/watch?v=xfe2Kr-zWVw
Ususally it takes about 4 hours to fully charge the RC. Theoretically the power level should go up if it has been charged for 2 hours.
2016-6-12
Anacapri
DJI-Paladin Posted at 2016-6-13 05:22
Ususally it takes about 4 hours to fully charge the RC. Theoretically the power level should go up ...
thanks Dji - Paladin ,
I sent a technical support email dji await response.
the remote control remains in office for two hours after it automatically turns off but has not loaded .
2016-6-13
Anacapri
Anacapri Posted at 2016-6-13 10:15
the remote control rem ...
I tried to do a reset seen online , could you give me the correct procedure for doing so ?
2016-6-13
DJI-Paladin
Anacapri Posted at 2016-6-13 16:22
Here you are:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the aircraft and the controller and link the remote.
2016-6-13
Mat_sealy
Flight distance : 1155 ft
4 hours to charge the RC that's fine....but how long does it last typically? Hopefully more than three flight batteries cos that's how many I ordered
2016-6-13
DJI-Paladin
Mat_sealy@hotma Posted at 2016-6-13 17:18
4 hours to charge the RC that's fine....but how long does it last typically? Hopefully more than t ...
Normally it can last 3 hours.
2016-6-13
Mat_sealy
DJI-Paladin Posted at 2016-6-13 11:23
Awesome thanks for the help
2016-6-13
DJI-Paladin
Mat_sealy@hotma Posted at 2016-6-13 18:58
You are welcome.
2016-6-13
Anacapri
I was contacted by technical support Dji Holland, I have to fill in form send it to them then I will have signs for repair . Really good service !!! I'll keep you informed on the matter
2016-6-13
