Unable to increase smart return-to-home height
1749 5 2016-6-10
Philj6970
Flight distance : 840663 ft
While having a fly around today I noticed a local high spot that I use as a landmark was higher than my auto return height.
I have 100 metres set but the hill is about 100 metres plus trees.
When I got home I tried to raise the set height for auto return home, but I get this message:
"Course reversal altitude cannot be higher than the altitude limit of 0m."
I have Max altitude set to 500, I tried setting it to 499 to refresh it but get the same message.
Anyone know what I'm doing wrong?
2016-6-10
Philj6970
Tried again with the drone connected.
Ok now.
2016-6-10
Alari
Switzerland
Yup, your drone has to be connected, because all the settings are stored to your drone, not the app. If you'd connect a drone to a new device the app will automatically load the settings, not the other way around.. This is because if you lose connection, the drone has to know the settings not app
2016-6-10
DJI-Paladin
Flight distance : 2408 ft
Hello Philj6970, when you set the MC settings, it is necessary to turn on the drone.
2016-6-11
Philj6970
DJI-Paladin Posted at 2016-6-12 17:26
Thank you both for your replies.
Also very very important to go through the app and put all your settings as you want them before flying after DJI Go update.
I got bad photos twice after updates, on manual both times with manual ISO-100 then AWB-manual and very blue.
Also flew with return home height way too low, good job it wasn't needed.
2016-6-14
DJI-Paladin
Philj6970 Posted at 2016-6-15 15:41
Also very very important to go through the app and put all your  ...
Reset the camera settings and use Auto mode to try again. Is every photo very blue?
2016-6-14
