R&L Aerial
Flight distance : 298100 ft
Here is a simple hack to make you z-axis work with your x5 camera, no spring cutting required. Simply remove the top spring cover on the z-axis using a 2 mm tool, then using small zip tie tighten the spring in half, cut excess zip tie then reinstall top spring guard. It seems to work great with x5 camera. ( do not remove lower spring cover as it will pull the ribbon cable loose and ruin your z-axis as I did with my first z-axis) removing the top spring cover with care, do this at your own risk!!!
