Inspire 1 Firmware v1.9.1.10
12
9350 59 2016-6-13
Wolfman
Flight distance : 405659 ft
R&L Aerial  Posted at 2016-6-17 09:06
After I finished updating to the latest and greatest my inspire pro beep DDD then disappeared.
Sorry for your loss R and L.... maybe next time anchor inspire to the leg of the table. It is well documented how they get so twitchy and excitable after an update, a bit like trying to keep a wild horse in a holding pen!
Wolf
2016-6-16
River One
Flight distance : 7691722 ft
Just wished to report that six batteries on 1.9.1 all fine ..
2016-6-17
snathla
Flight distance : 5045295 ft
Donnie Posted at 2016-6-15 07:05
For the Camera ED, 1.9 will only be for the Inspire Pro models  . Correct me please if I am mistake ...
Donnie - DJI Go app still does not reflect 1.9, it still shows 1.8+ after a few days and being on the internet etc...Not sure why, at least it was successful. The same Inspire Pro seems to always indicate lack of transmission even when the RC is 1 ft away. Go figure after spending $4K+.
2016-6-17
sdl56
Flight distance : 93924 ft
My FW update also shows + on the Ipad after several days
2016-6-17
Wieg1
After many days and many internet connections also my DjiGo on my ipad AIR2 continues to show +.
However all works fine ....
2016-6-17
Donnie
Flight distance : 3636782 ft
snathla@gmail.c Posted at 2016-6-17 20:27
Donnie - DJI Go app still does not reflect 1.9, it still shows 1.8+ after a few days and being on  ...
sign into DJI with the Go app device , see if it will  roll then.....
donnie
2016-6-18
sdl56
Did that with my pad
2016-6-18
Donnie
On your I pad , does it allow for auto updating ? Go to "settings"  on your i-pad and  open the "I tunes and  app settings" , make sure that under "Automatic Downloads " that the  "Updates " tab is enabled.
donnie
2016-6-18
Wieg1
....updates are enabled, in the the tab I made login in the dji page, I have left the transmitter, the aircraft and DjiGo on for a long time, nothing, it continues to show +.
Everything works correctly but this validation and + seems really pointless, frustrating and can cause misunderstandings and errors.
It does not make sense.
2016-6-18
Donnie
Wieg1 Posted at 2016-6-18 09:56
....updates are enabled, in the the tab I made login in the dji page, I have left the transmitter, t ...
Also be sure to do a  complete re boot of the Go app device, I pad whatever ,  I wish I knew the "Technical " reason on why this is necessary myself .  ( The + sign to the version )
donnie
2016-6-18
AEROKAMERA
Flight distance : 2289429 ft
Poland
Donnie Posted at 2016-6-18 17:06
Also be sure to do a  complete re boot of the Go app device, I pad whatever ,  I wish I knew the " ...
Did it all and nothing, still 1.8.01.00+
2016-6-19
Cougar1
Flight distance : 924393 ft
The + sign I believe is only that it has not synched with DJI servers, indicating the version is higher then (in this case 1.8.01.00).
The "automatic updates" has nothing to do with this, it is simply allowing the GoApp to update automatically, and has caused many pilots grief by updating the app without their knowledge.
Rebooting of  the iPad is not necessary, it is however good practise since it will clear some memory.
2016-6-19
Donnie
Cougar1 Posted at 2016-6-19 08:45
The + sign I believe is only that it has not synched with DJI servers, indicating the version is hig ...
Why not give some input on what will solve the problem then ?  ( Mine is at 1.9 and I have offered my settings and procedures as  an example ) You seem to know what will not work , therefore tell us what does......
donnie
2016-6-19
Cougar1
Donnie Posted at 2016-6-19 11:53
Why not give some input on what will solve the problem then ?  ( Mine is at 1.9 and I have offered  ...
As I wrote, it needs to connect and update to DJI servers. Nothing you or I can do, this might not be resolved until next update.
Important part is, as long as the text file shows success after fw update you are good to go.
2016-6-19
Donnie
Cougar1 Posted at 2016-6-19 10:16
As I wrote, it needs to connect and update to DJI servers. Nothing you or I can do, this might not ...
The challenge I have with that is why does it work for me and not others ?
Therefore I give suggestions as to what my settings are and what MIGHT work for others , You on the other hand just dismiss my ideas without coming up with any solutions .
Most pilots wonder why donnie's is working and not mine , and they are not satisfied with, "Wait till, the next update " So with some trial and error you can find a solution, I have fixed Multiple forum members aircraft with this approach.    How bout you ?
donnie
2016-6-19
Wieg1
I made also many re-boots.
...I repeat on this point, it is frustrating and can cause misunderstandings and errors.
It has not any sense.
I think Dji should give a solution without waiting for the next update.
2016-6-19
Cougar1
Donnie Posted at 2016-6-19 12:23
Therefore I give su ...
Not sure why you are so intent on getting a solution that you can't provide, it rests with DJI. Even if your intentions to help others is admirable I don't think you can, in this case.
As a footnote, mine also shows 1.9 .
2016-6-19
Donnie
Cougar1 Posted at 2016-6-19 10:31
Not sure why you are so intent on getting a solution that you can't provide, it rests with DJI. Ev ...
"Not sure why you are so intent on getting a solution that you can't provide,"
Well I sure as hell am going to try , and in the process I will learn something that I can help others with in the future.
donnie
2016-6-19
Cougar1
Donnie Posted at 2016-6-19 12:43
Well I sure as hell ...
Best advice I think you can give right now,  is to ensure users that as long as the text file hows "Success" after firmware update, the Inspire is indeed on the correct firmware. If the app shows + and the update is good, there is nothing to worry about.
2016-6-19
Wieg1
...I have reinstalled DjiGo app and the correct number of firmware is appeared...I hope that Dji will not use this kind of validation again.
2016-6-23
12
