How to change the default tilt on the H3-3d? (solved)
1516 5 2015-1-21
ouzedh.email
Hello all,
I got the Phantom 2 + Zenmuse H3-3D bundle. I'm not sure if this is the way it's supposed to be, or if this is something I need to adjust, but after I mount my camera on the gimbal, the default tilt is quite low, about 50 degrees. I can tilt it with the controller to slightly higher, or slightly lower.
Is it possible to adjust it so that the camera is pointing directly forward? I think this is possible and I've just messed it up somehow.
Thank you!
2015-1-21
freddiebd.email
Flight distance : 1891184 ft
Nope, this is correct just use the transmitter to make it horizontal.
2015-1-22
DJI-Dboy
China
try to calibrate X1 in your P2 assistant software
2015-1-23
ouzedh.email
Thank you, I got it - I needed to adjust it in the P2 software, as you said.
2015-1-24
oakspi
What was the result of your adjustment?  Mine points down.  I thought I did do the adjustment, but perhaps wrongly.
2015-3-2
oakspi
OK, I moved the middle adjustment in the gimbal programing all the way to the left and gained some improvement in angle. Perhaps to 35-40 degrees now.  I'm glad that I saw your posting.  Thanks
2015-3-2
